Home > In Car Electronics (L322) > 2002 radio - aux
BMG
United Kingdom 2002 Range Rover Vogue 4.4 V8 Bonatti Grey
2002 radio - aux
Scroll through the screen between cd, radio and tape, I also have Aux. What does this even do as there is seemingly no aux input and the radio booklet doesn't even make mention of it.
Cheers
Post #509451 21st Mar 2019 2:46pm
Zebedee
United Kingdom 2013 Range Rover Vogue SDV8 Santorini Black
There is a mod that can be done to the BM54 amp [which is in the l/h side of the boot] that adds the AUX option to the menu so you can play music from mp3s & phones.
People who do this mod add a cable into the BM54 with a 2.5mm jack plug to connect the phones to. My cable comes into the centre cubby box so I can connect the phone/mp3 player there.
I'd suggest you have a look at the BM54 to see if there is an extra cable coming out of it, and then try to follow that cable to see where the other end is.
I've used a company called Sound Secure in Rochdale to do a couple of these mods and he seems to know what he's doing. Current:
- 2017 L405 3.0 V6 Autobiography
Sold:
- 2013 L405 4.4 TDV8 Vogue
- 2004 L322 4.4 Vogue (BRC LPG)
- 2002 L322 4.4 HSE (having fixed timing chain guides)
- 2000 P38 4.6 Vogue (BRC LPG)
- 1981 2-door In-Vogue
- 1980 Ex-Army SIII LWB
- 1976 SIII LWB
- 1968 SIIA
Stripped for parts:
- 2003 L322 4.4 Vogue
Post #509457 21st Mar 2019 3:04pm
BMG
Many thanks. The car used to have a Parrot phone thingy fitted, would that be it ? I don't see any conventional aux in
Post #509581 22nd Mar 2019 8:07pm
Zebedee
I believe adding the AUX option is only a software change, so maybe it was done for some reason for the Parrott system. Current:
Sold:
- 1976 SIII LWB
- 1968 SIIA
Stripped for parts:
Post #509823 25th Mar 2019 6:37pm
I had my BM54 aux in upgraded by Baris
I had the choice of doing my own connections (inside the box, soldering wires to pins etc.) once he had done his thing,
or to have two phono sockets fitted to the case.
I went for the latter Thumbs Up
AFAIK a physical connection is required .
Post #509836 25th Mar 2019 8:18pm
