Home > Technical (L322) > Dodgy rear drivers window
noddy5vogue
United Kingdom 2003 Range Rover Vogue Td6 Java Black
Had a quick search and could see anything relating to the problem my ffrr2003my has ,Only happens occasionally but the rear drivers window will wind its self down and will have to wait about 10 seconds before i can wind it back up from the front switches happened twice last night on the m6 ,children were a sleep in rear and windows locked off from front to stop them playing with them.
Post #50895 19th Feb 2011 5:55pm
something is activating the window, maybe a loose connection or water ingress shorting the switch. ... - .- -.
Post #50898 19th Feb 2011 6:02pm
Sounds like it could be caused by water ingress in the window motor, or possibly a faulty switch or worst case scenario a faulty BCU
Post #50900 19th Feb 2011 6:06pm
daveo
check the multi plug at the bottom of the drivers A post,its right where the LCM is,check to make sure you have no windorscreen leaks here and its dripping, had any probs with your lights Question V8 facelift Range Rover Autobiography 22" wheels.
Post #50951 20th Feb 2011 12:10am
noddy5vogue
Thanks for your replies will have to wait till the weekend when i can have alook in the daylight as regards problems with the lights i sometimes get a warning for sidelight which i believe is a bad connection and goes on and off depending on which pothole we hit
Post #51201 21st Feb 2011 6:36pm
