Home > General > Supercharged Spec |
bozmandb9 Member Since: 06 Dec 2010 Location: Wallingford, Oxfordshire Posts: 1020 |
Well I think I'm just going to do it!
13th Feb 2011 7:43pm |
GolfLima Member Since: 20 Oct 2010 Location: South Bucks Posts: 18 |
Bozmandb9,
17th Feb 2011 6:19pm |
sharpm Member Since: 08 Nov 2010 Location: Central Scotland Posts: 33 |
If I'm following this thread correctly the OP is getting a gas conversion on an SC for £1500 ish
17th Feb 2011 7:55pm |
Too late now anyway chaps, I'm hoping to pick it up tomorrow if it's completed.
17th Feb 2011 9:57pm |
Ludzy Member Since: 27 Oct 2010 Location: Leicester Posts: 191 |
Well this is getting interesting now! Fingers crossed that it's all good. I'm just about to get the wife a fiat 500 for her to potter around in. Hopefully once a conversion kit has been successfully tested I'll sell that and get mine converted so really interested in your results.
17th Feb 2011 11:57pm |
Phil. Member Since: 19 Apr 2010 Location: West Midlands Posts: 784 |
Oh dear! As you say, too late now. Have you spoken to JE yet? You'll definitely be calling them shortly when the valves melt and it won't take 30k+ miles before they do. That's if you get that far. What LPG kit have you fitted? See my recent post on FFRR if you want an insight in my nightmare experience converting a 4.2 S/C to LPG. Best of luck mate, I hope it goes well. Please keep us informed. |
19th Feb 2011 10:48am |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6366 |
I was in JE on Friday last week and this came up in conversation. They mentioned they had done an early SC but it was problematic due to the hardened heads required.
19th Feb 2011 11:15am |
There seem to be plenty of Jags and RRS s/c which are happily running on lpg, and they all have the same heads. To be honest if its all going to go wrong then the sooner the better, since if its within two years then its down to the conversion place to stump up for the new heads!
19th Feb 2011 12:05pm |
Fantastic economy, is that from the computer or manual calculations? If I can get that from lpg I'll have a 30 mpg s/c! Range Rover-less at the moment - Pining! |
19th Feb 2011 12:08pm |
If the price ratio between LPG/Diesel is still the same as a couple of years-a-go then it will cost the same in fuel as a 30-35mpg diesel. Typically 200-230 miles from a 90ltr (70ltr actual) tank. |
19th Feb 2011 2:04pm |
It's not just about the heads, it's the set up that will cause most problems unless you are very lucky. For some reason (probably software) the engine management on the 4.2 S/C RRS is different to the 4.2 S/C FFRR. Most of the RRS 4.2 S/C LPG conversions set up well. The FFRR 4.2 S/C seems to be more complex and it's very difficult to get a good balance between running on Petrol and LPG. It's often ok for one but not the other. This makes for all sorts of problems because a cold start is always on petrol and then it switches to LPG at a pre-set temperature. So in practice both set ups have to work and if one of them isn't working well then all sorts of running problems occur. The 4.2 S/C engine management software is also constantly adjusting itself, making a good set up even more difficult to achieve. You may get a good set up for a while and then it automatically adjusts and problems occur again, often different ones. If you have half the issues I did then you will be driving around with the yellow engine management light on or waiting for it to come on every time you start it. If your LPG guys get problems setting up the system initially then you may consider asking them to remove it completely and immediately before it ruins the petrol operation. It will be a lot cheaper and less hassle than trying to make the LPG system work in the longer term. I did exactly what you are doing now 2.5 years ago on a 55 plate MY2006 with 20k miles, so appreciate your reasoning and enthusiasm. Best of luck! PS While I'm thinking about it. Due to the calorific value of LPG, when making use of the 400bhp 4.2 S/C, the LPG has to switch to petrol on high load and then back again to LPG. This change over point can also be a point that set up problems occur. I don't know if mine had a fuel return line but it does seem to be the holy grail for the 4.2 S/C according to the LPG forums. |
19th Feb 2011 2:23pm |
Hi Phil, I appreciate all the advice, I just think LPG conversions are progressing very rapidly. I've heard of set ups able to deal with up to 500bhp now, which wouldn't have been possible one or two years ago! I would certainly consider asking them to remove the kit if it turns out to be a nightmare. If the kit wasn't capable of handling the 400bhp, it would go back as well! I'm having the Lovato SGI fitted, which I read through the forums seems to be the ideal for this application. Phil, out of interest, if you could find out if your car had the fuel return line fitted, it would be really helpful. Please see below quote from LPG forum: Hi The possible problem with the Range Rover Sport is the same as I had with my Jaguar XJ 4.2 which uses the same engine. Engine running bad and engine light on all the time, it was hard to find a solution however when we did it was an easy fix. The light on was due to the petrol fuel pressure getting to high when running on gas and the management system was trying to make adjustments. The Jaguar and Range Rover need a return fuel line if you want smooth running and the light out. My return was fitted inside the tank, this will take the pressure off. Just check your fault codes to see if it shows fuel pressure code. I hope this may be of help, if you need any more information or help let me know. Packie. If your convertor didn't fit one then it looks like this was almost certainly your problem. Range Rover-less at the moment - Pining! |
19th Feb 2011 4:51pm |
I read that post earlier. It's about the RRS and Jag XJ rather than the FFRR.
19th Feb 2011 5:07pm |
I haven't got my car yet, but I have found a very successful prior conversion to a 4.2 s/c FFRR. It's a guy on Pistonheads, I found one of his posts and e-mailed to enquire about his gas conversion and received the e-mail below:]
20th Feb 2011 2:48pm |
