Home > Maintenance & Mods (L322) > Rear Wheel Arch corner rust!
Bazzer79
United Kingdom 2007 Range Rover Supercharged 4.2 SC V8 Barolo Black
Morning All!
A year or so ago I noticed some bubbling of the paintwork on the rear edge/corner of my NS rear wheel arch. It's slowly got worse and yesterday got back to my car that had been out in the wind and rain to find the paint had flaked off exposing the unsightly mess in the pic below. It's hopefully just surface rust, if you give it a good prod it's solid. Fingers crossed, but I confess I don't have any prior experience of rust repairs.
I've recently spent a fortune on maintenance on my Fatty so a proper bodyshop repair will have to wait 3/4months. In the mean time I'd like to prevent it from getting worse and also tidy it up so it's not so unsightly.
Any advice is much appreciated. Is it a case of rubbing it down as much as possible and then treating it with a anti corrosion solution and applying some paint?
Post #508799 15th Mar 2019 10:35am
Fraynizzle
United Kingdom 2005 Range Rover Vogue Td6 Java Black
you can get rust converters that should stop it getting worse but you may need to expose a lot more of the surface under the paint to get all of it.
Post #508800 15th Mar 2019 10:40am
DrRob
I'd probably put a light smear of grease over it to keep it at bay for a month or 2 Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #508804 15th Mar 2019 11:24am
Full Fattie
United Kingdom 2007 Range Rover Vogue SE 4.2 SC V8 Zambezi Silver
This was mentioned in another thread recently and I said I didn’t know of anywhere that sold repair panels. Has anyone found any in the past. These seem to be more and more common as a problem area, this and the sill.
Post #508811 15th Mar 2019 11:49am
Ian928
Norway 2006 Range Rover Supercharged 4.2 SC V8 Java Black
I have the same thing, You can be pretty sure that needs welding. I hoped it was just surface rust, but when I started to sandblast the area there was lots of pinholes through the body.
Repair panels would be a good thing. 2006 Supercharged
Post #508928 16th Mar 2019 4:42pm
kimlahti
Finland 2008 Range Rover Vogue TDV8 Alaska White
I had only small bubbles visible on paint and it was like lace underneath. Shocked
https://www.fullfatrr.com/forum/topic38485-32.html -08 3.6 Vogue
-87 951
Post #509489 21st Mar 2019 7:28pm
