Home > Maintenance & Mods (L322) > Improve braking on a RR 4.4 TDV8 313cv |
Bluewater9118 Member Since: 07 Mar 2016 Location: Angerville Posts: 31 |
Hello
14th Mar 2019 7:06pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35326 |
why do you think the current brakes arent working properly????? |
14th Mar 2019 8:26pm |
SFM Member Since: 19 Feb 2012 Location: dordogne Posts: 258 |
I must admit after 6 yrs of driving the 3.6, with Brembo brakes, I do find my 2012 does not stop, anywhere near as quickly.
14th Mar 2019 9:30pm |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2485 |
Are the pads glazed? Mine seem to be very aggressive after towing my 2T van. |
14th Mar 2019 10:56pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16288 |
What pads are you running? Lots of NON OE pads do NOT work on the 6 pots... And as 322's & 405's get a little older, sent to indies that fit ECP specials unfortunately |
14th Mar 2019 11:33pm |
So what is the recommended choice guys? |
14th Mar 2019 11:52pm |
gonna_go_double_r answer
15th Mar 2019 5:47am |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3544 |
Yes those are the ones.
15th Mar 2019 7:20am |
Over £200 for brake pads!!
15th Mar 2019 8:40am |
Bushy30 Member Since: 03 Jun 2018 Location: Oxfordshire Posts: 1098 |
I've just fitted the standard EBC's available from Island4x4 -- all good so far Current: 2011 FFRR Vogue SE 4.4 TDV8
15th Mar 2019 9:21am |
I have TRW GDB1834 at the front and TRW GDB1824 at the rear. |
15th Mar 2019 9:45am |
Craig you don't rate EBC's then?
15th Mar 2019 10:53pm |
No no sir... I don't rate Mintex, Textar and especially the Brembo crap ECP's sell as its all ! and do NOT work on the 6 pots! EBC have worked on every car i have tried them on thus far... Just not tried them on a RR yet sir |
16th Mar 2019 12:27am |
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 |
I have yellow stuff on my fronts and they are overkill , greenstuff more than up to the job. Yellow stuff won't fade and under normal driving nor will green stuff. Maybe your pads or discs have an issue ? 2015 4.4 AB
16th Mar 2019 12:42am |
