Home > Maintenance & Mods (L322) > OSR Caliper sticking |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3774 |
I just had the front discs and pads done because as well as a wobble on slowing they were also the cause of a bit of squeaking. The wobble has gone but the squeaking persists so I investigated and found the OSR caliper sticking slightly, warm after a long drive while the other is cold. So my question is has anyone had long lasting success by cleaning and lubing or should I just bite (expensive on a 5.0L S/C) the bullet? Geoff |
14th Mar 2019 8:11am |
Fraynizzle Member Since: 27 Apr 2015 Location: Essex Posts: 111 |
My TD6 has the ATE callipers I had a sticky rear caliper so rebuilt them with new pistons and seals. Fixed it for a while buts it’s back. I’d just get a new caliper... more cash but should last a lot longer. |
14th Mar 2019 9:10am |
I tell you what dolph - Kildare to Doncaster is some trip - BTW thanks for the advice, more expensive maintenance Geoff |
14th Mar 2019 10:00am |
Shaun Member Since: 02 Jul 2010 Location: Hull Posts: 58 |
Fixed mine by ordering a new piston and seal kit from Brakeparts.co.uk and refurbished myself. 2004 TD6 - Gone
14th Mar 2019 12:13pm |
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 |
Hi Geoff , just a quick jaunt across the pond ( while we still can !!!) . I have been informed that the early calipers do fit and work no problem ( and they are cheap as chips) but i decided to stick with the 'correct ' part.
14th Mar 2019 2:53pm |
kooky_guy Member Since: 25 Nov 2011 Location: Sandhurst, Berkshire Posts: 385 |
My OSR started intermittently seizing shortly after having the discs and pads replaced.
14th Mar 2019 3:23pm |
Jri711 Member Since: 26 Feb 2019 Location: Norfolk Posts: 20 |
I’ve had this happen on the rear of both my l322’s & on both occasions I’ve removed the caliper pumped the piston to near fully out, gave it a dam good clean with brake cleaner, a little lube with engine oil pushed the piston back in and refitted. Worked both times for me , so maybe worth a go as costs nothing but a little of your time if your confident enough to try. |
14th Mar 2019 5:28pm |
Yep just rang the Indie, just over 620 quid for the one side including new pads, I had the other done a while back. I think someone suggested getting them both done - should have listened Geoff |
14th Mar 2019 8:38pm |
Pawl Member Since: 07 Nov 2017 Location: West Midlands Posts: 688 |
I'd strongly suggest nobody uses engine oil to lubricate any brake pistons or seals as it is incompatible with brake fluid and is very likely to cause the piston seal to swell / distort significantly. The caliper may continue working for a while, but there's no telling whether it will end up leaking or jammed. Paul,
15th Mar 2019 9:10am |
