![]() | Home > Maintenance & Mods (L322) > Fuel Additives... |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3247 ![]() ![]() ![]() |
Am I correct in remembering that if you use 2stroke it should be mineral and not synthetic? John
Mineral |
Grofus Member Since: 24 Mar 2017 Location: Co Clare Posts: 577 ![]() ![]() ![]() |
I use Dipetane regularly now after a sticky fuel pressure regulator in the high pressure fuel pump was causing havoc. I could run it as long as the engine revs stayed above 1200 rpm. Below that it went straight into limp mode. I was told the only cure was a new pump at €1600 plus labour.
Jri711 Member Since: 26 Feb 2019 Location: Norfolk Posts: 20 ![]() ![]() ![]() |
So ok t2 is good for our td’s & we should use mineral not synthetic, but dose anyone know at what ratio? |
200:1 is about 0.5l per tank full.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35510 ![]() ![]() |
obviously Australian product's... |
gettingold Member Since: 03 Apr 2018 Location: Wiltshire Posts: 285 ![]() ![]() |
Good job the lids are on those bottles |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3874 ![]() ![]() ![]() |
Tesco is my nearest garage, I've used both diesel and Petrol from there for over 40 years without any problem. I did try some additive in my diesel RR (previous to this one) put it in religiously (even bought a measuring thingy) I'm not sure it made any difference. But all the arguments are of the "is there life after death" type - no one really knows. Geoff |
not fact, but an opinion.... |
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 ![]() ![]() ![]() |
I had to post the pic upside down so you mob in the northern hemisphere could see it properly. 😆 ______________________________
I'm not entering the debate, the only "fact" I know is what I posted me, SWMBO, son and daughter use Tesco fuel all the time and haven't had any problems - the kids aren't old enough to have been using it 40 years (43 to be precise, today is my wedding anniversay) I taught SWMBO to drive back in the day so she doesn't have 40 years with her own car either. The stuff I used in the Diesel was BG422 or is it BG244 or BG 224 or BG 442 who knows, who cares. Geoff |
congrats to you and your wife on your wedding anniversary geoff.. |
Thanks Stan. Not easy to fix pic orientation on a phone. ______________________________
