Home > Technical (L322) > TD6 Exhaust leak manifold to turbo- gasket change
Richycsurfer
United Kingdom 2004 Range Rover Vogue Td6 Bonatti Grey
How bad of a job is this to tackle?
Airbox off, grommets out, turbo bolts and simply change or am i hoping too much?
Post #508432 12th Mar 2019 3:47pm
Fraynizzle
United Kingdom 2005 Range Rover Vogue Td6 Java Black
not done it myself but looking at the manual the only extra steps it mentions beyond what you have said is moving the wiring harness next to airbox, removing the exhaust front pipe, remove the turbo intake fron airbox - i guess all for access.
snap shot from manual below showing some of the turbo fixings.
Post #508441 12th Mar 2019 4:24pm
Richycsurfer
Hmm. Thank you for that, very useful. Maybe it is a job i will tackle myself afterall. Do you know where a gasket may be available?
Post #508442 12th Mar 2019 4:29pm
Fraynizzle
advanced factors have the part here:
https://www.advancedfactors.co.uk/8510327a...1152-p.asp
or you can create a topic in the site sponsors section if you wanted parts from Dan @ duckworth.
Post #508446 12th Mar 2019 4:42pm
Richycsurfer
Thank you, i've ordered one. Access makes it seem a horrible job but hopefully i'll be pleasantly surprised like with the starter motor!
EDIT: just realised i ordered one for a P38 due to the fact i just googled the part number - hopefully they share the same pattern (the pic looks identical also!)
Post #508449 12th Mar 2019 5:13pm
holidaychicken
I don’t feel too guilty linking to the competition as I’m always sending people over here.
This might help, I have had the turbo off at least 3 times I think.
https://www.landyzone.co.uk/land-rover/td6...oo.253209/
Post #508483 12th Mar 2019 9:01pm
Richycsurfer
Thanks, shame the pictures are down but I'll have a good read.
Post #508484 12th Mar 2019 9:02pm
holidaychicken
I added some pictures further down because the original ones were missing
Post #508485 12th Mar 2019 9:25pm
