![]() | Home > In Car Electronics (L322) > 2004 TD6 No Sound |
You may need to have a look INSIDE the various boxes at the back, BM54 (Radio), SatNav, TV module, DSP/Amp.
Boydonegood Member Since: 12 May 2014 Location: Essex Posts: 445 ![]() ![]() ![]() |
Thanks Joe!!
Sound should work with the Satnav disconnected, so mostly likely the DSP/Amp or the BM54 .
Thanks buddy
Sorry to resurrect this thread.
MadL322 Member Since: 09 Oct 2018 Location: Yeovil Posts: 108 ![]() ![]() ![]() |
have a full set up thats taking up room if you want for £160 and a bit of postage |
At a guess, it is the black amp that has gone South
Cheers guys
have a look, listed on ebay and just about anywhere else I can list to get sold, although will let it go for £160 on here + delivery.
You could try wiggling the speaker cables on the top of the dsp unit, the cables connected to the two front plugs, and see if anything happens. |
Cheers for the tips guys, Unfortunately havent got any further with this. Disconnected all and re plugged back in.
Or... go for this, Xtrons Ts119L. nice and big, hardware to the fuse in the glove box and rewire speakers. all the toys for £169 |
MadL322 Thanks for the message fella!!
sounds no different tbh. internal amp on the unit pushes 45w per channel and no need for additional cables that you'd need if you went down the dsp bypass route that everyone thinks you have to go. rewiring the speakers is easier than re-routing a 6m cable from the back to front and then extra expense to bypass the dsp |
