Home > Technical (L322) > IID causing reset of everything
Andy
Guys is this normal?
I entered CCF mode to enable DRL (the fairy lights). It all uploaded then I heard the clock rewind backwards to 12 o clock. Then it said Upload failure. However the DRL's are on now. All I had to do was reset the time/date and all my radio stations again.
Post #507729 7th Mar 2019 9:25am
MikeO
Scotland 2009 Range Rover Vogue TDV8 Buckingham Blue
Did you have an external power supply connected? 2016 Skoda Octavia VRS Estate
<gone>2009 FF Vogue TDV8 Buckingham Blue</gone>
<gone>2015 BMW 520D SE (not my favourite car)</gone>
<gone>2009 D3 HSE Galway Green</gone>
Post #507734 7th Mar 2019 9:41am
MikeO
I *think* a reset is normal with a change to CCF, it was the failure I was concerned about. 2016 Skoda Octavia VRS Estate
Post #507736 7th Mar 2019 9:43am
dolph34
Ireland 2015 Range Rover Autobiography SDV8 Corris Grey
Mine does this too , says upload failure but upload does work and i have to reset everthing. 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #507758 7th Mar 2019 12:33pm
Andy
No
Post #507848 7th Mar 2019 7:16pm
you need to have the engine running...it will stop and start during the process, this is normal..
Post #507851 7th Mar 2019 7:27pm
Andy
I did. It switched off the ignition and restarted it. Then it all went off and the clock wound back
Post #507852 7th Mar 2019 7:29pm
good..the reset is a pain but it doesnt take long to set the clock etc..
Post #507857 7th Mar 2019 7:38pm
