![]() | Home > Maintenance & Mods (L322) > Access height door switch |
There is no separate fuse - however if your door card has been off it may have not been plugged back in correctly.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35463 ![]() ![]() |
after 8 years of use it might be the contacts are no longer 'contacting', whip it out and have a look.... ... - .- -.
was the wire on my one when i first got it,as dan said the door card had been and the wire was not put back right V8 facelift Range Rover Autobiography 22" wheels.
Reformed Member Since: 09 Oct 2010 Location: South Posts: 471 ![]() ![]() |
Thanks guys. Do I have to remove the door card to get at the switch or can I remove the tweeter speaker above it and pull the switch up to have a look? Reformed |
M44K TS Member Since: 09 Feb 2010 Location: North East U.K. Posts: 1325 ![]() ![]() |
I think the switch pack is screwed in from behind the door card so you will have to remove it.
