Home > Maintenance & Mods (L322) > Back seat problems
littlecub
Australia 2003 Range Rover HSE Td6 Epsom Green
Back seat problems
Recently I took out the single back seat when I went on holidays to give me a bit of room.
When i went to put it back in the metal clip( on the base) that holds it to the floor has closed and I dont know how to release it so that the seat will sit properly.
Also the double seat back wont go up from being in the folded position,it will go back a bit but then it wont go any further.
Any clues regarding both problems greatly appreciated.
TIA
littlecub
Post #507450 5th Mar 2019 11:17am
rjff
If your single seat is fixed down at the front as it should be, perhaps try operating the lever which allows you to tilt the seat back forward. I think that would release the catch that is closed, or allow you to fiddle it open. You may have to fold the seat fully flat or even stow competely then move back to as it should be. Cheers
Richard
Gap IIDBT
Post #507454 5th Mar 2019 11:36am
littlecub
Got the single seat sorted, now to get the double seat back in the upright position.
It will go up about 1/4 of the way then it gets blocked. Evil or Very Mad
Any ideas greatly welcomed.
littlecub
Post #507567 6th Mar 2019 9:09am
These might help:
TIP: Rear seats won't fold back up?
60-side of 60/40 rear seat stuck folded down .
Post #507569 6th Mar 2019 9:17am
