Home > Maintenance & Mods (L322) > Drivers seat switch surround panel
BMG
United Kingdom 2002 Range Rover Vogue 4.4 V8 Bonatti Grey
The dull chrome like film on the drivers seat switch surround panel is lifting off. Is is possible to sperate this part from the rest and replicate the chrome like finish ?
Thanks
This is the part I mean.
https://www.ebay.co.uk/itm/Black-Range-Rov...rk:21:pf:0
Post #506419 26th Feb 2019 2:23am
Jsteed
Hi, yes the chrome trim is removable. I have the same problem.
You could remove the trim and coating and vinyl wrap or repaint with a similar finish.
Alternatively, I found these.....
https://www.aliexpress.com/item/A-Pair-New...649bn5Gbvg
Post #507160 3rd Mar 2019 4:07pm
BMG
Cheers. Think I'll take a chance on the AliExpress stuff and see how it goes.
Post #507459 5th Mar 2019 12:46pm
BMG
The cheapy AliExpress parts arrived today. Not fitted yet, as would like to find some paint to finish the plastic panel which these attach to first and do in one go.
They look OK. Not quite a chrome effect as the originals or as reflective, but since new ones are unavailable, they will look a damn sight better than the flaking mess I have right now. I'll caveat that buy saying, if they fit that is.
Anyway, a comparison.
Post #508950 16th Mar 2019 9:49pm
ur20v
A Trap
Looks like your seat foam has failed which means you are now flexing the chrome trim and this lead to the chrome finish delaminating, your new trim will do the same and eventually crack if you don’t replace the Lower seat foam.
Post #508969 17th Mar 2019 8:48am
Highroller
United Kingdom 2005 Range Rover Vogue SE 4.4 V8 Java Black
I would agree with what ur20v says. I'm surprised that the side panel is still attached. But changing the foam I assume would be a PITA (excuse the pun) anyhow.
Post #508971 17th Mar 2019 9:46am
An easy non expensive fix would be to take the two front seats out and change the seat base's over... The outside of both will then be like new Thumbs Up
Post #508977 17th Mar 2019 10:28am
BMG
This is the passenger seat, which doesn't look that worn next the drivers side.
Is a seat foam available ? I did a quick Google but nothing really came up .
Post #509006 17th Mar 2019 6:35pm
Jsteed
Those Aliexpress parts look great for the price! I look forward to hearing how you get on with fitting them. I'm sure they will fit fine.
Here is the result of my efforts. I used 4d carbon vinyl and an aerosol of Ford Sierra beige. The colour match is fantastic. I was not at all concerned about recreating the rubberized finish bmw applied.
Post #530053 4th Oct 2019 4:57pm
Tinman
United Kingdom 2017 Range Rover Autobiography SDV8 Silicon Silver
Hi, Price for seat base from Duckworths £94 filler part £38 this is for a 2011 year
Post #530077 5th Oct 2019 8:18am
