Home > Technical (L322) > Pulleys and belt replacement 4.4 TDV8
edward19
My stolen recovered range rover has finally burst into life. I had codes for metering fault and coolant temperature sensor out of range. I believe it was also run out of diesel and it would only start on 'easy start'. After sending the high pressure pump to Ribble valley diesels / Diesel Bob, the pump was found to be ok. However when putting back on the car, fuel pressure returned and the vehicle seems to work perfectly. I no longer have any metering fault codes, Phew!. However my auxillary drive belt is not sat quite flush on one pulley and is makes a squealing noise. A bit of wd40 shut it up for a few seconds but I think I need to change the belt and pulleys. Does anyone have a manual extract on how to remove the fan shroud etc, so I can get to everything.
Thanks
Post #507048 2nd Mar 2019 8:55pm
dolph34
Ireland 2015 Range Rover Autobiography SDV8 Corris Grey
https://www.fullfatrr.com/forum/viewtopic.php?p=506281#506281 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #507053 2nd Mar 2019 9:13pm
edward19
Thanks. Sorry I should have checked before posting
Post #507055 2nd Mar 2019 9:14pm
dolph34
Thumbs Up Thumbs Up 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #507056 2nd Mar 2019 9:15pm
