Home > Technical (L322) > Transmission query
Andy
Transmission query
I lost drive on my TD6 a couple of weeks ago and had to be recovered home. The car reversed off the trailer and onto my driveway where it’s remained ever since.
It’s being picked up in the morning to have the transmission replaced. The problem is, if I select N, it won’t roll back on the driveway.
Is the transmission locked? Can it be freed to put on a truck?
Post #506765 28th Feb 2019 10:25pm
RRPhil
If you place a (5A) fuse in position 37 in the fuse box in the glovebox and switch the ignition on, the transfer box should move into Neutral. Even if your transmission is stuck in Park for whatever reason, this will allow the vehicle to roll.
Phil
Post #506773 28th Feb 2019 11:46pm
Andy
Thanks Phil. I’ll try that.
Post #506783 1st Mar 2019 7:55am
Andy
Put the fuse in but still won’t roll. It could be the brakes stuck after two weeks though so we will attempt a tug when the tow truck arrives
Post #506802 1st Mar 2019 9:26am
