Home > Technical (L322) > 2012 TDV8 help needed |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4302 |
Perhaps drop it by an independent close by to read codes and shed any light? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
26th Feb 2019 9:31pm |
www.rcv.co.uk
26th Feb 2019 9:37pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8504 |
Turn off the seatbelt warning as a starter for 10....
26th Feb 2019 10:32pm |
nicksaab Member Since: 28 May 2013 Location: Wimbledon and West Wales Posts: 560 |
With regards the seatbelt light - you didn't have anything on the passenger seat did you like the handbook? Mine is quite sensitive if I have something on the passenger seat but no belt done up and it can and does trigger the seatbelt light as things move about.
26th Feb 2019 10:33pm |
Plus it won’t blow to heat up the cabin when you first start it up.....as the engine isn’t warm, so it waits until it can blow warm air. Otherwise it would blow cold air at you.
26th Feb 2019 10:42pm |
paulbrown22 Member Since: 23 Dec 2017 Location: London/Poole Posts: 352 |
Yes, Auto temp in these models seems to be very discreet. My fiancé was convinced it wasn't working when we picked up ours last year, as you really can't hear anything, especially when compared to the full manual mode when the fans start blasting away.
26th Feb 2019 10:43pm |
SFM Member Since: 19 Feb 2012 Location: dordogne Posts: 258 |
Nmj
26th Feb 2019 10:47pm |
Can’t remember off the top, there’s instructions on here. Something to do with plugging in and ejecting the seatbelt seven/eight/nine times.
26th Feb 2019 10:55pm |
V8 Bob Member Since: 15 Mar 2018 Location: Cumbria Posts: 357 |
To check oil stop with hot engine on level ground, wait ten minutes then go into service menus using buttons on right side of steering wheel, select check oil level in service menu 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
26th Feb 2019 11:37pm |
Cheers guys
26th Feb 2019 11:58pm |
Where did you purchase it from? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
27th Feb 2019 1:35pm |
Tried my manual fan this morning. Doesn’t do much if you just turn up the fan. You get more fan, but you have to change all air direction settings to feel it.
27th Feb 2019 5:26pm |
