Home > Maintenance & Mods (L322) > Drivers door handle not working |
kds2 Member Since: 30 Sep 2017 Location: lincoln Posts: 222 |
If you mean the outer door handle not working then its door card off, been there done that same year. |
20th Feb 2019 9:25pm |
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3137 |
It’s normally the “nugget” at the handle end of the wire that corrodes and snaps or jams. It’s not a big job if everything is loose and comes out ok. Mine was rusted into the hole so had to drill it out to get the new wire in. Once the door card is off it’s actually quite easy to replace (if everything is movable as I said)
20th Feb 2019 9:42pm |
Mine had seized at the handle end, had to take handle off to sort it in the end no way would it let go of the nipple, gave it a good dose of copper grease to delay it doing it again. |
21st Feb 2019 12:35am |
DannyH Member Since: 30 Apr 2015 Location: Hull Posts: 221 |
had to change mine the other week, same thing the nipple on the end snapped off the cable.
26th Feb 2019 1:42pm |
littlecub Member Since: 02 Apr 2013 Location: Ulverstone,Tassie Posts: 325 |
Just tried to get the nub out,bloody tough little nub.
1st Mar 2019 2:53am |
