Home > Technical (L322) > Locking wheel but removal tool stuck
ohuntsman
United Kingdom 2002 Range Rover Vogue 4.4 V8 Zambezi Silver
Hi! Any tips for getting the old bolt out??
Post #506371 25th Feb 2019 8:43pm
Put socket in vice
Tap/Bash screwdriver/drift or similar through hole until wheel nut comes out .
Post #506375 25th Feb 2019 9:02pm
ohuntsman
I should of said that it was one of these- I don’t think it will knock through?
Post #506376 25th Feb 2019 9:04pm
Ah Smile
Put one end in a vice
Turn the other end with mole grips or plumber's wrench, attack with hammer to break joint
Alternatively, put it back on the car then you can use the wind up force to un wind ? (then pop something inside the socket so that when you go to undo again the thread does not go to the end and lock it up
Or find a suitable bolt that fits and do the same in the vice
Some heat
Combination of the above.... .
Post #506393 25th Feb 2019 10:12pm
kds2
England 2008 Range Rover Vogue TDV8 Stornoway Grey
Cant you trap the wheel nut in a vise then turn the removal tool as though you you are tightening the wheel up ?
Post #506394 25th Feb 2019 10:14pm
ohuntsman
Thanks chaps!
Post #506437 26th Feb 2019 11:26am
ohuntsman
Ok did thus and it worked. It won’t take out my next lug though!!
Put a load of washers on to stop the bolt going on too tight and plenty of copper slip
That really loosened the tool off, but had to remove the bolt again which tightened it back up - not as much though!
Then with the pipe wrench flat on the floor I could undo it
Post #506522 26th Feb 2019 9:32pm
vaz
United Kingdom 2007 Range Rover Vogue TDV8 Java Black
I suggest you remove all the locking wheel nuts, chuck them in the bin and replace with standard wheel nuts.
No one steals wheels from vehicles anymore, they just take the whole car.
Steve. 1968 Series IIA Pastel Green, nearly there project
Post #506633 27th Feb 2019 11:22pm
jim4244
England 2005 Range Rover Vogue Td6 Zambezi Silver
What Vaz said 👍
Once had a flat on my old D3 which luckily happenend on my driveway. When I tried to undo the locking wheel nut it sheared internally and just spun.
I had to cut the piece that was spinning off with a dremal tool and then hammer a socket on the stub that was left. All in all it took around 2.5 hours. Imagine if I had been on a country lane at night in the middle of winter? I would have been totally Censored !
Jim
Post #506641 28th Feb 2019 9:16am
