Home > In Car Electronics (L322) > Strange goings on...
jonlewis
2007 Range Rover Vogue TDV8 Buckingham Blue
Hi All,
Any thoughts appreciated.
So today my car has no sound from the various devices such as Radio etc.... Amplifier, I hear you say... welll maybe, but maybe not.
Navigation - Works no sound
TV - appears on menu but when you press it the radio stays on screen....same for DAB, portable music.
Phone - connects and can dial etc... but no sound.
I can understand the Sound/Amp, but it seems a stretch that would leave me with a seemingly working, but unselectable group of other inputs.... but some that can be selected.
Anyone else experienced this ?
Jon 2011 Stornaway Grey 5.0SC Autobiography
Post #506299 25th Feb 2019 12:00pm
Bushy30
United Kingdom 2011 Range Rover Vogue SE TDV8 Galway Green
Hi Jon,
Yes -- I have!
First time it happened an overnight of 'doing nothing' fixed it, second time it happened soon after I actually put the IID tool on it and cleared all the faults which fixed it -- not happened since -- though the entire system did a reboot on a 3 hour journey a few months after all of the above.
Have you got any logged faults?
Bushy Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
2004 FFRR Vogue 4.4 V8 with LPG
1997 P38 4.0 SE with LPG
1997 P38 4.6 Vogue with LPG
Post #506300 25th Feb 2019 12:10pm
jonlewis
Faults cleared, one of which was a MOST communications error.
On the IID, it does look like anything downstream of the BT Module is showing as ‘Not Fitted’ despite showing in the CCF as fitted.
Post #506309 25th Feb 2019 1:14pm
Bushy30
Did it all come back, or still problematic?
Have you got a MOST loop kit? -- from others experience it's likely to be the BT module -- if you don't have a loop kit you could use the 'BIC biro' method as a temporary test. Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
Post #506311 25th Feb 2019 1:17pm
jonlewis
No change from clearing the faults so, need to read up on the biro method of testing 2011 Stornaway Grey 5.0SC Autobiography
Post #506330 25th Feb 2019 2:33pm
Bushy30
Thumbs Up Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
Post #506332 25th Feb 2019 3:13pm
