![]() | Home > Camping, Caravanning and Holidays > Another newbie with van |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1368 ![]() ![]() |
Who did the lpg conversion ?
Super7 Member Since: 23 Feb 2019 Location: Somerset Posts: 19 ![]() ![]() |
Chap called Mike Scott at GAS in Huddersfield, I'm a small time LPG fitter myself and run my own bulk tank, but I believe Prins are the only guys who supply the kits for these so my hands were tied, I can buy the kits but cant get access to the software unless you are a prins registered installer, his work is not the best tidy wise but he is known for his expertise on the 5.0 s/c lpg fitting, works flawlessly (so far) |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16339 ![]() ![]() ![]() |
I have two customers with the same setup... Ones done 70k in his since LPG was fitted... |
Sounds promising, by the same guy or someone else? I bought mine at 51,000 and it’s just turning 60,000 so early days yet, I shall be looking for someone to service the lpg next year if anyone has any recommendations? South west preferred. |
IanV8 Member Since: 14 Jan 2010 Location: Dunfermline Posts: 502 ![]() ![]() ![]() |
Nice set up. I’ll not ask about consumption towing as I know how low mine can get.
fmecaj Member Since: 15 Mar 2021 Location: London Posts: 6 ![]() ![]() ![]() |
hey Charles,
I’m now at 73,000 with it being fitted at 51,000 only issue I had was when the engine was stripped for timing chains etc. It threw a fault up when it was reassembled, quick chat with Mike Scott to reset it and it was sorted, otherwise it’s been running sweet.
Thank you very much for the info, very useful indeed.
There’s a fair bit of stripping out to do to fit the Lpg system so it would make sense to have the person doing the conversion to do them at the same time.
Thank you Charles, much appreaciated! |
Not all 5.0 are effected by timing chain guides, I have the list of engine numbers somewhere of the ones involved (certain batch of poor quality guides), it’s the tensioner guides that were the problem not the chains themselves, the tensioners wear the guides, as the tensioners pistons push into the guides they wear the alloy and eventually get to the end of their travel so can’t maintain pressure on the chains, you’ll get plenty of warning by the rattle.
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3552 ![]() ![]() ![]() |
I've read the 5.0 can't be converted so it's great to hear yours is proof it can be done . |
Last year Prins were in the process of producing a kit for the 5.0 SC 405, I would imagine that must be in production now so they certainly are convertable. Current 5.0 S/C Autobiography LPG
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35651 ![]() ![]() |
another point to consider is the apparent lack of available lpg stations now..seems like they are being phased out... ... - .- -.
