Home > Technical (L322) > OE Tow Bar Swap, 2008 to 2011
Philip
2019 Range Rover Autobiography SDV8 Aintree Green
My local dealer has suggested that the wiring loom of the LR tow bar on a 2008MY car is incompatible with a 2011MY car.
I assume that the tow bar and armature are otherwise physically capable of being swapped between the cars and that the correct loom (listed as Part No. VPLMT0007) is dealer-fit - can anyone confirm?
Post #50566 17th Feb 2011 12:15am
nbunney
If the part numbers for both armatures are the same, then yes.
Which loom are you on about?
If the 1 with the trailer sockets on then easy to do it yourself and just plug it in. You will get good enough instructions with the loom.
Post #50571 17th Feb 2011 7:15am
Philip
Thanks, haven't checked part numbers but assumed the armature was identical.
I did mean the wiring ending in the trailer light socket - are they definitely a simple plug-in to an existing factory socket on the vehicle? Never had a close look.
Post #50621 17th Feb 2011 1:25pm
nbunney
When I alled 1 on the TD6 there is 1 module required and a couple of Plugs.
Have a look in behind the right hand panel, where the fuse box is. The trailer contol box is a grey baox on the right.
If you get stuck let me know
Post #50623 17th Feb 2011 1:48pm
