Home > Maintenance & Mods (L322) > L322 replacement gearbox?
jim4244
England 2005 Range Rover Vogue Td6 Zambezi Silver
Hi all
I will be looking at a 2005 Vogue , with 98,000 on the clock, on Monday. I have questioned the current owner regarding the gearbox but he is unaware if there has been any work carried out on it.
Is there anything that would indicated that it has been changed or flushed that I could glean by a visual inspection under the car?
Jim
Post #506103 23rd Feb 2019 11:14am
Discotigger
Look to see if the bolts holding the gearbox sump have been changed or removed and replaced. This would give an indication that the gearbox oil and filter could have been changed.
If you decide to buy it, get the gearbox oil and filter done straight away. It's good preventative maintenance and will help to give you some confidence in the condition of the gearbox.
Post #506110 23rd Feb 2019 1:11pm
GDM
United Kingdom 2006 Range Rover Vogue Td6 Zambezi Silver
Re: L322 replacement gearbox?
jim4244 wrote:
Hi all
Jim
What engine is it?
Post #506153 23rd Feb 2019 11:14pm
jim4244
A TD6.
Post #506156 24th Feb 2019 12:35am
jim4244
Was the original sump on the TD6 gearbox made of plastic?
Jim
Post #506187 24th Feb 2019 1:03pm
RRPhil
Nope, it’s steel. Generally, the GM 5L40-E transmission in the TD6 L322 lasts between 80,000 and 100,000 miles before a major rebuild is required due to valve body wear. There are exceptions, of course, and regular fluid changes (Dexron) will help prolong its life by reducing spool oscillation which causes the wear. The wear results in leakage and subsequent pressure loss, allowing the clutches (particularly the torque converter lock-up clutch) to slip and burn.
Phil
Post #506189 24th Feb 2019 1:26pm
jim4244
Thanks Phil
So what should I look for underneath to indicate that either the gearbox has been changed or the oil changed?
Jim
Post #506192 24th Feb 2019 1:49pm
RRPhil
Sorry to sound so cynical but how certain are you that the present owner isn’t selling because they’ve just started noticing issues with the transmission? It’s at just about the right mileage for that. If the car is still on its original transmission it would be prudent to budget for a £2,000 bill for a replacement somewhere further down the line.
There’s no certain way of determining if the fluid or the transmission has been changed just from a visual inspection, unless of course it looks much cleaner than everything else under there or the bolt heads give it away. The green plate on the casing tells you the year of manufacture but it’s unlikely that a new unit would have been fitted anyway, much more likely a re-manufactured one.
2003 transmission:
I guess the owner would know if the transmission has already been replaced because you don’t forget spending that amount of money in a hurry!
Phil
Post #506224 24th Feb 2019 6:41pm
