Home > Technical (L322) > Broken drivers seat (and steering wheel adjust) diagnosis
AutoBiL322
Hi All,
I am now a 2 L322 family having bought a beautiful 2006 MY (12/05) Java Black Vogue.
I am going to attempt to fit 2012 seats into her but in the meantime the drivers seat adjustments (all of them) do not work and it is almost undriveable as it is so erect.
The steering wheel adjustment is also not working.
Passenger side all fine.
I have researched on here and google but really not sure where to start.
Could anyone with experience talk me through where best to start on this? Would really appreciate it.
Many thanks
Post #506092 23rd Feb 2019 8:43am
PaulTyrer
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Cairns Blue
We had a drivers seat fail and it turned out to be a break in the wiring loom under the seat
Because of the constant forward and backward movement one of the wires broke. Took a bit of finding though!
Post #506106 23rd Feb 2019 11:52am
AutoBiL322
Thank you .. it is possible. Hopefully its a relay or fuse rather than random damaged cable.
Fuse board seems a good place but seems odd steering wheel and seat not working at same time.
Post #506107 23rd Feb 2019 12:51pm
AutoBiL322
An update on this .. I checked both fuses (20 and 23) both are ok.
I changed the switch pack for a known working pack from my other L322 ... that didn’t work.
I have looked underneath and all looks in good order. Pushed and prodded everything I could see.. checked all the connections visible were pushed into place.
Anyone with any experience suggest a next move? Thank you
Post #506211 24th Feb 2019 4:40pm
AutoBiL322
I still cant find the fault or anyone to fix it.
My next move is to work out what cables feed power to the seat and temporarily rig up a battery to power it directly.
I need to work out what cables to power up though.
Post #506940 1st Mar 2019 11:06pm
RR P38
Australia 2003 Range Rover Vogue 4.4 V8 Java Black
How did you get on with this issue?
I have the same issue
So far I have pulled the switch pack appart all looks well inside all the switches register on activation on my scanner.
No visible issues with wires anywhere
I pulled the back off the seat, no issues there either
All fuses intact
If I move a switch repetitively in quick time I get the smallest movement and have managed to get a decent seating position.
It is like there is a power supply issue, power is there but not enough
Post #560345 6th Jul 2020 1:21am
