![]() | Home > Maintenance & Mods (L322) > Oil leak from vanos solenoid and top chain cover |
bruno22rf Member Since: 08 Mar 2018 Location: milton keynes Posts: 69 ![]() ![]() ![]() |
Might be wise to check your PCV and relevant pipework if you are getting top end leaks? |
JoeRRV8 Member Since: 03 Feb 2017 Location: Yorkshire Posts: 9 ![]() ![]() ![]() |
Did the PCV valve and hoses last year so there all ok. I’ve changed the upper chain cover gasket now and solenoid gasket and the answer is no you don’t need to remove the solenoid you can slide the cover over it, the worst bit about the job is the SAI pipe which runs from block to block, if anybody else does this just remove the pipe completely to save you a lot of time and messing about and make sure it’s seated correctly when you refit. |
Out of interest, how difficult was it to do the PCV? - got to do mine soon, I read that one of the pipes (the smallest one?) is a right pita to replace? |
