![]() | Home > Maintenance & Mods (L322) > Brake Caliper refurbishment |
Full Fattie Member Since: 10 Aug 2018 Location: Sunderland Posts: 245 ![]() ![]() ![]() |
When I had a set of Brembo calipers on a previous car someone had manufactured a set of pins that could be reused. Is anything similar available for these? |
gavinn Member Since: 11 Apr 2017 Location: west midlands Posts: 60 ![]() ![]() |
Steering Specialists Ltd
kezbo1981 Member Since: 20 Jan 2015 Location: Evesham, Worc Posts: 334 ![]() ![]() ![]() |
Bigg Red in Worcester |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16306 ![]() ![]() ![]() |
Wet paint them will suffice... Mask up the pistons and rubbers etc... Much easier sir |
poworoy Member Since: 12 Apr 2013 Location: West Yorkshire Posts: 9 ![]() ![]() ![]() |
can recommend:
fanders Member Since: 10 Jul 2013 Location: Hants, UK Posts: 318 ![]() ![]() ![]() |
How much do they charge for overhaul and repaint on a pair of four pot L322 Brembos? I’ve a couple that need doing.
I only had one done- maybe a discount for a pair? approx £150, if they have to replace a bleed nipple (they put an insert in rather than just re-tapping) then extra £25 2008 Range Rover Vogue TDV8 |
Thanks, useful info |
