Home > Technical (L322) > Rear diff not happy |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2257 |
Rear diff is whining a bit so put car on lift and seal has gone to offside drive shaft
15th Feb 2019 4:52pm |
stu1 Member Since: 06 Dec 2013 Location: UK Posts: 276 |
Please do update - I have a feeling mine is going in a similar direction...
15th Feb 2019 6:42pm |
Yes correct the locking diff
15th Feb 2019 10:58pm |
Thanks Craig hadn't thought of that but makes perfect sense |
16th Feb 2019 6:38am |
Excellent, thanks - looking forward to seeing your progress and just how difficult it is! Where did you find the replacement diff - I've been watching ebay like a hawk but haven't had much luck. I believe the correct part number is LR009627 for reman (and the original part number is TVK500331). |
16th Feb 2019 11:21am |
Marvellous, just to make it an even cheaper job |
16th Feb 2019 11:22am |
I found one at a breakers down in Glastonbury I use them for bits for my p38 and classic |
16th Feb 2019 12:05pm |
Right so took the diff off and the bearing on the offside shaft was knackered and the casing had broken down hence the squealing - I had a quote of 2k plus vat to rebuild it but bought a 2nd hand one for 250 quid plus vat from a breaker I have used in the past for Classic bits. It cam out of a 2008 with 70k on the clock and the manufactured date supported this so new seals from Dan at Duckworth and fitted and drives like new again. Interestingly there used to be a bit of schlep when power was taken off and put back that has gone as well. The oil in the bad diff was black and it had been changed less than 10k miles ago so all in all a good result - took me about 6 hrs to do.Hardest bit was getting the hub off the drive shaft |
25th Feb 2019 8:18pm |
Nicely done! Were there any particular problems outsides of the hubs? Did you need to remove the exhaust? If you;ve got a basic step-by-step that would be great |
25th Feb 2019 9:19pm |
Just dropped the exhaust didn't remove them |
25th Feb 2019 9:54pm |
