Home > Maintenance & Mods (L322) > Braking Issue
Infiltrator
United Kingdom 2010 Range Rover Vogue TDV8 Bonatti Grey
Braking Issue
Ok, Front discs and pads changed, fluid also changed.
Since then, I've been having an issue with the brakes, in that when I first press the pedal, the car brakes normally, however, if I come to rest, then the pedal will slowly sink to the floor. If I pump it, it immediately becomes solid, as I'd expect, but if I keep on the pressure, it will again, slowly sink to the floor.
Brake lines have all been bled again, no air. I don't appear to be losing fluid.
What could be going on please?
Post #505231 15th Feb 2019 3:19pm
Pawl
England 2007 Range Rover Vogue TDV8 Cairns Blue
Did you ever do the same "test" previously ?If yes, was it the same ?
Superficially, the result indicates that the mastercylinder is leaking internally, across 1 of the high pressure seals.
Assuming it was ok previously, most likely is that bleeding disturbed some dirt / debris & it's now lodged on the outer lip of one of the main pressure seals. Alternatively, full stroke during bleeding has damaged 1 of the seal lips when it moved into an area of the bore not normally used.
If you're very lucky & it's the former, you might be able to 'wash" it off by pressing the brake down & releasing it fast a few times or by pressure bleeding with the brake pedal held partially down.
If it's the latter, it's time for a new mastercylinder. Paul,
2001 Discovery 2 TD5, 211,000 miles & climbing
2006 FFRR TDV8 Vogue 145,000 miles & climbing
Member of Midland (Land) Rover Owners Club, www.mroc.co.uk
Post #505233 15th Feb 2019 3:47pm
Henda
United Kingdom 2006 Range Rover Vogue TDV8 Zambezi Silver
I presume your ff is diesel ?
If it is this is normal and is known as diesel creep something to do with the air intake or something
If your car stops normally and you can hold the car on light pedal pressure then it's fine if the pedal goes hard on switching off then that's ok
Do a search on diesel creep to set your mind at rest Thumbs Up
Post #505234 15th Feb 2019 3:48pm
^+1 for diesel creep.
Post #505237 15th Feb 2019 4:01pm
Infiltrator
And we have a winner!
This is exactly what I am experiencing. Well, well. I had never noticed before. I think that, as I had changed the discs and pads on the front, and also changed all the brake fluid, I just automatically suspected that I'd done something wrong, or broken something in the process. I re-bled the brakes twice, assuming that I had got air into the system.
Yes, I can hold the car on light pressure, and the pedal is rock hard when switched off.
I've even just gone to my wife's 3.0d X3, and it does exactly the same thing. Probably not quite to the floor, but very close.
Thank you so much, looks like I did the job right then.
That's what I love about RR ownership, there's always someone who knows what's going on.
Thanks again
Post #505252 15th Feb 2019 6:09pm
stu1
United Kingdom 2007 Range Rover Supercharged 4.2 SC V8 Java Black
Ummm, what if you were descending a long steep hill with a caravan on the back - what happens when the pedal hits the floor? You have to keep pumping the pedal?
Post #505288 15th Feb 2019 8:22pm
berkshirelad
United Kingdom 2007 Range Rover Vogue SE TDV8 Tonga Green
Only happens at idle
Post #505290 15th Feb 2019 8:27pm
