Home > Technical (L322) > TDV8 4.4 Coolant temperature sensor location
edward19
Hi All
I'm trying to find the location of the coolant temperature sensor on the 4.4 TDV8. I know it's been covered before but the pictures in the posting don't open. Please could someone post a location image.
Many thanks
Post #504809 11th Feb 2019 12:46pm
item number 5,
Post #504819 11th Feb 2019 2:27pm
edward19
coolant temp sensor location
Many thanks, so that's inlet manifold off first, oh great!!!
Post #504829 11th Feb 2019 4:04pm
nino_nino
if you remove throttle body you will have enough space to unplug and remove sensor.
Thumbs Up 2012 TDV8 Black Edition
2000 Disco. TD5
1975 series III
Post #504909 12th Feb 2019 3:10pm
Baltic Blue
If you are having problems with both the oil level sensor and the water temperature sensor, I wouldn’t rule out some form of “electrical “ issue before I started changing sensors.
I like Stan’s starter for ten, check the fuse, get a voltmeter on it and go from their.
Post #504913 12th Feb 2019 3:51pm
GraemeS
Fuse 5E (#5 in the main engine bay fuse panel, not the auxiliary fuse panel in the same box) supplies the oil sensor but also several other components so is unlikely to be the cause. The coolant temp sensor is not supplied with power from a fuse.
With water getting onto the battery I would check the condition of the ECM connectors as the ECM is adjacent to the battery and water may have penetrated the connector contacts.
Post #504951 12th Feb 2019 7:58pm
