Home > In Car Electronics (L322) > Replacing the head unit on the cheap
Danbhardy
United Kingdom 2003 Range Rover Vogue Td6 Adriatic Blue
My 2003 hse stereo hasn’t worked since I got it.
I’ve got a double din stereo already and all I want is some music in me car!
Is this doable?
Post #504642 9th Feb 2019 6:28pm
easily replaced with an android unit...do a search and read this from our wiki,
https://www.fullfatrr.com/forum/topic29219.html
Post #504643 9th Feb 2019 6:33pm
Danbhardy
Yeah have read that. Makes no sense to my simple mind!
I’m just after putting a stereo in that plays music, not worried about the original functions!
Post #504644 9th Feb 2019 6:53pm
Paul thornton
Depends what system is already in there and whether it has built in amps or if the car has individual amplifiers ie logic 7. If it's a head unit with built in amplifiers then a simple adaptor lead is required. If not then you will need to bypass the amps.
The hole in the dash isn't actually double din sized although it looks it. A double din will fit but a lot of work is required cutting plastic behind the dashboard.
Post #504674 10th Feb 2019 9:01am
Danbhardy
There’s a dash adapter I can get.
Mine is the hse so standard in dash CD player.
Post #504675 10th Feb 2019 9:03am
Paul thornton
Not seen the dash adaptors before but if it works it should be simple enough. I don't think the hse will have individual amps.
Top of the dash needs to come off to remove the original radio though.
Post #504678 10th Feb 2019 9:08am
Danbhardy
Yeah, seen the video for that Smile
Just need some noise Smile
Post #504679 10th Feb 2019 9:15am
p38arover
Australia
That thread says the pix have been reinstated but they don't appear. Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #504683 10th Feb 2019 10:00am
mjdronfield
Might be easier to get another hse unit from a breakers and do like for like swap.
Should be possible to swap out with something else.
Have you checked RAVE for the connection details? Or maybe looked at BMW stuff, as it’s the sa,e electronics?
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #504685 10th Feb 2019 10:02am
Mr Tee
Scotland 2019 Range Rover SVAutobiography 5.0 SC V8 Waitomo Grey
I had a double din unit fitted in my old hse. Depending on the size of the unit, a fair amount of the plastic behind the dash has to be trimmed . The android unit appears to be an easier fit because it’s a better shape to the rear. One thing we did find out is that if you have a cente dash speaker, there will be a small amp in the left cubby in the boot. IIRC you need a trim piece from an e39 5 series to fill the hole . Not too daunting if you are handy with some basic tools, or find s9meone local to fire one in. I ran about for ages with a Bluetooth speaker in mine when the stereo packed up!
Post #504695 10th Feb 2019 11:28am
mjdronfield
This might give you an idea of what you can get?
https://www.dynamicsounds.co.uk/ctklr04-la...g-kit.html
Single DIN video here
Is this what isn’t working on yours?
https://www.ebay.co.uk/itm/RANGE-ROVER-L32...SwkJNbjaJw 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #504706 10th Feb 2019 1:05pm
Danbhardy
I don’t know as I don’t know much about the stereo.
It lights up when the lights are on but nothing is displayed on any of the displays and no sound.
It came on twice for 5 second bursts once but nowt on display when it happened.
Post #504852 11th Feb 2019 7:55pm
