![]() | Home > Maintenance & Mods (L322) > Washer Jets |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16339 ![]() ![]() ![]() |
Are they not just frozen sir? Don't know how warm the weather has got down your neck of the woods? Seems strange they have both blocked! Remove the tubing going to your bonnet then press wash and see if you have flow first |
Simon123 Member Since: 02 Jan 2018 Location: Pembrokeshire Posts: 32 ![]() ![]() ![]() |
Thanks for reply. They were working normally until last week until there was a bitof snow on bonnet. I've disconnected rubber tubing and pump is working and there is water flow.
mpirie Member Since: 26 Jun 2012 Location: In the Highlands Posts: 910 ![]() ![]() ![]() |
Each washer jet has a lip at the front (windscreen) and a squeezy tang at the rear (bonnet front).
Hi Mike,
JCW Member Since: 13 Apr 2013 Location: Cotswolds Posts: 909 ![]() ![]() ![]() |
Having had the same problem after freezing, once removed I've disassenbled the jet unit, inside is a small spring and a small red rubber grommet that appeared to have been dislodged from its normal position and blocked any fluid flowing through to the jets.
^ Spot on. |
Thanks for advice, will try the suggested remedies before I order new jets |
