![]() | Home > Technical (L322) > 2004 td6 turning over but no start and various warnings |
gj88 Member Since: 10 Sep 2018 Location: West Midlands Posts: 213 ![]() ![]() ![]() |
Last time mine would turn over but not start it was the secondary fuel pump. Have you tried getting under the osr and seeing if the pump is working? It's just 2x10mm bolts to undo to open the little hatch, with the ignition at position 2 you should be able to tell if it's working. If not, a few smacks with your spanners should get it going until you can replace. If it is working, no idea I'm afraid! |
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1196 ![]() ![]() ![]() |
For some reason unkown to me, (OK, I was dicking around), I got HDC, ABS, and others on the dash yesterday, but it did start.
