Home > Maintenance & Mods (L322) > AIR CON HOW to DISABLE L322 2006 V8
Blue Hornet
Australia 2006 Range Rover Vogue 4.4 V8 Zambezi Silver
I am about to replace cam cover seals and the manual says to degas system and remove AC pipe over cam cover.
Does anyone know how to cut the power supply to AC unit (other than disconnecting the battery)
I want to remove either the AC fuses or relay so the AC has no power whilst I am working on car as I will have to drive it to see if the seals are ok after install and I definitely dont want the AC unit accidentally turned on with the pipe removed.
I have found 2 AC fuses in the glove compartment but I cannot find the AC relay and not sure which is best to remove to disable the AC unit completely.
Post #504098 5th Feb 2019 11:38pm
gavinn
Pull the electrical connection to the AC Clutch , no compressor no AC ? But this will not help with the gas escaping if you disconnect any pipes !
Post #504105 6th Feb 2019 7:18am
Paul thornton
If you are removing air con piping then you will have to get the air con system de-gassed first. You can't just blow it off into atmosphere plus it is pressurised with or without the system running.
Obviously it will need to be re-gassed when you're finished.
Post #504115 6th Feb 2019 9:58am
gavinn
And if the system is degassed it will not run anyway as the pressure sensor will not allow it to run in a depressurised state
Post #504118 6th Feb 2019 10:37am
