![]() | Home > Maintenance & Mods (L322) > Heavy Duty Plastic Car Ramps |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4334 ![]() ![]() ![]() |
During Bodsy’s visit to do a group gearbox Megaflush I noticed he used some interesting plastic car ramps.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35650 ![]() ![]() |
+1 for an ebay purchase...mine are very sturdy and light to carry about.. |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7911 ![]() ![]() ![]() |
Think I’ll give these a miss |
bargain!! |
MikeO Member Since: 02 Jan 2018 Location: The Cotswolds Posts: 528 ![]() ![]() ![]() |
Rhino Ramps I think are the originals. Very cheap in the US but the shipping is a killer. I have a pair and use a piece of carpet underneath to help accommodate uneven surfaces. Highly recommended. 2016 Skoda Octavia VRS Estate
PaulTyrer Member Since: 22 Jul 2013 Location: Devizes, Wiltshire Posts: 1261 ![]() ![]() ![]() |
Is it because they are made from real Rhino? |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 ![]() ![]() ![]() |
this are mine Extra heavy duty high lift ramps cc 10~15 quid. (not so light) |
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 ![]() ![]() ![]() |
![]() GSXR 1000 K5 R1 1998 |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6419 ![]() ![]() |
or DIY
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3552 ![]() ![]() ![]() |
Great thread! DrRob I did notice those in the original post.
TomV8 Member Since: 25 Sep 2017 Location: Yorkshire Posts: 107 ![]() ![]() ![]() |
DrRob,
Would the L405 on these ramps enable me enough access to get under the car (without axle stands or anything else) and safely clean the inside dishes of the alloy wheels, as well as doing diff/ transfer case oils) etc?
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8750 ![]() ![]() ![]() |
Says they’ve got a 16cm lift, so if you add that to the 295mm in off road height then I reckon there will be about 450mm under the car which should be plenty to get under. There is nothing that can't be fixed with a hammer😜😜
