Home > eBay & Bargain Spots > L322 bargain deployable side steps
topgeartowers
Duckworth’s on EBay have some L322 deployable side steps for a bargain £425. Brand new, all the kit and 2 year warranty.
Bought a set and had them fitted last week - very happy!
Post #503653 2nd Feb 2019 10:41am
Dolphinboy
Don’t forget if you want to remove any wheels (to fix a puncture etc) the handbook advises you HAVE to remove the steps in order to access the jacking points on the chassis.
Post #503657 2nd Feb 2019 11:16am
Or a good top tip... Deploy your step then unplug it! It cannot try to close on you and gives you piece of mind when jacking up Thumbs Up
Post #503658 2nd Feb 2019 11:18am
S.Hafsmo
Norway 2007 Range Rover Vogue TDV8 Orkney Grey
I gave £174 for a complete set from Brit Part.
 2007 L322 3.6 TDV8 Stornoway
Post #503680 2nd Feb 2019 3:13pm
Dolphinboy
@Craig,
where do you unplug it from? There is a button in my roof to switch off but it doesn't work. How can i find out why not?
Is it a fuse or a physical link gone?
Post #503693 2nd Feb 2019 3:53pm
James, they unplug at the front hinge, just behind the sill cover... Very easy to unplug (when you know where they are) Thumbs Up
Hope the family are well especially the little man Thumbs Up
Post #503694 2nd Feb 2019 4:05pm
mrtidy
United Kingdom 2009 Range Rover Vogue SE TDV8 Zermatt Silver
I got a set from farnells via eBay for £375.I was going to fit them myself but on removing the old fixed side steps the first bolt sheared off when trying to loosen it. So took the fatty to land ranger in stockport for them to fit and they said every single bolt sheared off so def glad I didnt carry on myself..Very happy with them. 2009 Vogue SE Zermatt silver
Post #503700 2nd Feb 2019 5:06pm
topgeartowers
This kit doesn’t contain all the bits you need - so for a new install, it would be more than the advertised price.
Post #503710 2nd Feb 2019 6:21pm
S.Hafsmo
Cable set was £111. Do you need more parts for a retrofit? 2007 L322 3.6 TDV8 Stornoway
Post #503729 2nd Feb 2019 8:01pm
dolph34
Ireland 2015 Range Rover Autobiography SDV8 Corris Grey
You can also just leave a door ajar Thumbs Up 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #503752 2nd Feb 2019 10:16pm
S.Hafsmo
Dolphinboy wrote:
@Craig,
Turn ignition on, within 10s, hold the button for 3 sec. They'll then stay in their current positions until next ignition cycle 2007 L322 3.6 TDV8 Stornoway
Post #503754 2nd Feb 2019 10:25pm
dolph34
+1 for the above but i changed my wheels today and i used a forklift with strategically place lumps of 4 x 4 timber so the door method gave me piece of mind even though i sure the factory way would have been fine Thumbs Up 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #503757 2nd Feb 2019 10:31pm
Dolphinboy
Thx hafsmo
Which button are u holding within the 10 seconds?
Post #503759 2nd Feb 2019 10:32pm
dolph34
In the roof console , where the button for the depolyable side steps is Thumbs Up 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #503762 2nd Feb 2019 10:38pm
