Home > In Car Electronics (L322) > FBH using a remote issues
jaysta10k
United Kingdom 2014 Range Rover Vogue SE SDV8 Santorini Black
Hi guys thought I would buy a FBH remote off flea bay as read loads of articles on here that the remotes are compatible from 2005 upwards to 2012. I have MY2006 with webasto and I have copied exactly what many forum users have advised disconnected the Power lead from the webasto module wait 30 seconds reconnect they press off button on remote until lights go out to pair the remote. A questions for those already us8ng these remotes when you press either on or off should the remote light green fior a few seconds then flashred about 6 times this is what mine does. Also my timed heating works fine within car when set manually.
Cheers Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
Audi A4 2.7 TDI S Line Black Edition phantomn black
Previous Cars
Range Rover Vogue SE Overfinch Styling 22" Elara's full black stealth colour coded
Java black Range Rover sport 2.7 TDV6
Alaska white Range Rover sport overfinch 3.6 TDV8
BMW M3 Carbon Black
Post #503376 30th Jan 2019 8:40pm
Bushy30
United Kingdom 2011 Range Rover Vogue SE TDV8 Galway Green
From memory I think it means the battery is flat Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
2004 FFRR Vogue 4.4 V8 with LPG
1997 P38 4.0 SE with LPG
1997 P38 4.6 Vogue with LPG
Post #503382 30th Jan 2019 9:17pm
jaysta10k
Hi mate cheers for reply yeah I thought the battery might be dodgy so tried another but still got the same flashes. Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
Previous Cars
BMW M3 Carbon Black
Post #503383 30th Jan 2019 9:26pm
Nick Evans
I dont think that style remote will work with an L322 you need the older one!
Post #503385 30th Jan 2019 9:39pm
drakes
United Kingdom 2010 Range Rover Vogue TDV8 Stornoway Grey
I think the fast flashes means it has not paired properly, I had this problem with mine and I had to change the reciever unit as there was nothing wrong with the remote. If you know someone with a working set up you could try pairing your remote to their car to prove if it works or not. 2010 3.6TDV8 Stornoway Grey/ Black interior - gone
2005 4.4V8 (M62) Bonatti Grey/ Parchment interior - gone
1998 4.6HSE Blue/ Cream interior (can't remember exact colours) - gone
1977 White - gone (should have kept)
Post #503388 30th Jan 2019 9:39pm
jaysta10k
Hi Nick there are many forums members saying that they have paired up the T90 remote to their vehicles being the L322 models. Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
Previous Cars
BMW M3 Carbon Black
Post #503392 30th Jan 2019 9:54pm
