![]() | Home > Technical (L405) > L405 SDV8 turbo failure |
MJGH Member Since: 15 Jul 2018 Location: Essex Posts: 102 ![]() ![]() ![]() |
Have not had a turbo failure (fingers crossed) but have noticed a number of threads relating to turbo failure on the forum.
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1784 ![]() ![]() |
The are still affected by the same issues, but in the name of fuel economy and emissions, mechanical sympathy goes out the window |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3756 ![]() ![]() |
Switching off after a fast run is the worse thing ever for a Turbo, it kills them. Not only does it allow the Turbo to continue spinning without any oil feed, but the extreme heat can carbonise what oil is left in it, which in the longer term blocks oil feed.
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3550 ![]() ![]() ![]() |
What's the right spin down time after a hard right foot?
Approx 5 mins if possible. The circulating oil also acts as a coolant, drawing the heat out of the turbo, so as long as is practically possible |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35476 ![]() ![]() |
surely most high speed journeys end with a slower route to your house/office etc thus giving the turbo time to spin down... |
Stan - Not in this scenario ^^ best course of action is to switch off the auto stop start function - it’s dangerous at a fast junction anyway when you need to pull out sharpish - especially where visibility is compromised 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
understood.. |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7969 ![]() ![]() ![]() |
I've had that argument with my wife - why I insist on leaving the engine running when filling up at a motorway services - the ones in France all seem to have the fuel at the end of the entrance slip road. |
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 ![]() ![]() ![]() |
Your right Stan , unless your barreling up to your front door at maximum revs , a gentle mile or two is ample to cool the turbo (s) down. To get both turbos spinning on an RR is no easy feat anyway and with these engines motorway speeds barely has the engine ticking over let alone spooling the turbos up. I've had turbo timers on high performance stuff in the past but those had engines that woulnt pull the skin of a pudding without the turbo spooling. RRs have plenty of grunt without spooling so the turbos aren't worked extensively like tuned jap stuff.
Huwrhys Member Since: 07 Feb 2018 Location: Hornchurch Posts: 548 ![]() ![]() ![]() |
I was told that the introduction of intercoolers completely did away with the need to run the engine at idle before shutdown. Was I wrongly informed? |
@john..i think that driving habits help as well..i always slow down to a mundane 40/50 mph before my motorway exit ...
Red Merle Member Since: 19 Sep 2016 Location: Cornwall Posts: 2158 ![]() ![]() ![]() |
@ Huwrhys: All that an intercooler does is cool down the turbo compressed air, to make it more dense, before it enters the combustion chamber. It should have no beneficial affect at all on cooling the turbo’s bearings and oil.
FWIW, we have run plant, equipment and LR and RR’s with Turbo diesels for almost 40 years. All have been allowed to spool down and idle for a minimum of 30 to 60 seconds or more defending on how they have been worked. In 40 years we have never had a Turbo failure, we have had a few engine failures but nothing involving a Turbo. 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
