Home > Technical (L322) > what else will i need for sat nav fitting on no nav rr |
JW911 Member Since: 09 Dec 2008 Location: Hampshire, UK Posts: 228 |
I'd be tempted to stick to plan A. I had an aftermarket Kenwood system fitted. It hooks up to the iPhone, has full functionality with the steering wheel buttons and I had the MID (trip computer controller) relocated from the dash to the glovebox where the CD changer used to live. Wasn't cheap unfortunately but I'm keeping the car so I thought "what the hell".
15th Feb 2011 8:22am |
Or there is this thing, it's designed to look completely OEM, there was a really good post about it somewhere but I cant seem to find it. Perhaps someone could oblige.
15th Feb 2011 8:46am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35284 |
got to admit these after market chinese jobs aint that bad...i put one into my smax and although a bit clunky it did work pretty well... ... - .- -.
15th Feb 2011 8:50am |
pretlove Member Since: 10 Feb 2011 Location: Bas vegas Posts: 1865 |
i brought my hse from the auction and some idiot had stuck a Vogue badge on the back so i just assumed it was a Vogue but other than the sat nav im very happy with the car it seems to have all the extrs apart from satnav and heated rear seats plus its a very clean version with low miles for its year and it is in my opinion the best colour (light silver) or at least its the colour i wanted .....if i decide to go the standerd range sat nav route do you know if ill need anything else like loom or extra modules to control it..............dan i like that lookalike stereo its very close to the origional in looks |
15th Feb 2011 9:06am |
wow that looks good but if im onist i dont want to loose the multichanger |
15th Feb 2011 9:09am |
It has been discussed a few times before, mainly ending in the fact that the cost is prohibitivly expensive as it means entire interior out job (seats, dash, carpets etc). I believe you would need: New Radio Unit (the BM54 integrates a lot with the nav) Used: £300 Different Amp (I don't believe the low-line amp has nav input/output) Used: £300 Nav computer: Used Mk3 £200 Used Mk4 £350 Nav Screen: Used £300-£500 Antenna: Not sure, £100? Associated wiring needed: £1K? So a total install price of £2000-£2500 would not be far off. I imagine if you were really clever and bought smart and over time you could probably get that down to £1500. Maybe even 1K if you fudged some bits. Either way, that's generally the diff between a Vogue and an HSE and there are a LOT of extra's you get in a vogue... That being said - the copycat install as above is probably the closest to OEM you're going to get, thatand its designed to work with the limited HSE systems. D |
15th Feb 2011 9:37am |
cheers mate looks like ill be going the aftermarket route what other extras does the Vogue have that mine wont have as i do seem to have a lot of buttons the only differance i can see is the nav and heated rear seats
15th Feb 2011 12:14pm |
Completely different seats (13 way adjustable and much more comfortable)
15th Feb 2011 12:30pm |
By way of example, my HSE has Xenons, front parking sensors and a couple of other Vogue bits.
15th Feb 2011 1:50pm |
we do have some 'vogue vigilantes' here mate so dont worry to much..i'm in the same boat as you having a hse but with all the vogue bits except for the sunroof and the badge of course.... ... - .- -.
15th Feb 2011 1:57pm |
Hey Pret,
Hi pretlove, mate has an oem nav with a custom retrofit harness (not avail from LR) - gbp1400 PM if interested ------------------------------------ The prob with aftermarket is that you still don't have all the i-Bus items (such as clock, on-board computer, etc.). I've retrofitted a nav to mine. http://www.fullfatrr.com/forum/topic2737-45.html 2nd post down. I took much more apart than you'd have to. With the retrofit harness, it's basically plug n play. The install requires removal of the upper dash, center console, left rear seat section, and trim between the LR door and the trunk area where th satnav mounts. It's actually not that bad to do: the better part of a day the first time and much less if you ever decide to do it again. Let me know if you're interested. I'd def do it again. In the mean time I've fitted bluetooth, a phone cradle in the center console, and am still working on a fully integrated car pc. RRC 2Dr, RRC 4Dr, P38, and 2 L322s (wife thinks I'm nuts - prob right, too) |
15th Feb 2011 5:39pm |
i agree i think ill keep the HSE as mine must have a lot of extras as i also have the Bi-Xenon Lights ,front and rear parking sensors plus its got the Vogue 20 inch alloys plus as with yours mine has only done 70,000 miles with full dealer service history with paperwork from universal studios to back it up and drives like a dream and as for the seats i cant see how they could be any more comfortable and the only bit that is not electric is the headrest im very pleased with the car just not the stereo due to the lcd issue......i appreciate the advice guys but i must say selling the car is not a route i wanna take as im very happy with the one i got |
15th Feb 2011 10:34pm |
[quote="SteveMFr"]Hey Pret,
Hi pretlove, mate has an oem nav with a custom retrofit harness (not avail from LR) - gbp1400 PM if interested ------------------------------------ The prob with aftermarket is that you still don't have all the i-Bus items (such as clock, on-board computer, etc.). I've retrofitted a nav to mine. http://www.fullfatrr.com/forum/topic2737-45.html 2nd post down. thanks steve i may go this route ive been offered the dvd unit and the screen for £280 so will all i then need to get is a harness if so where can i just buy one of those thanks again buy the way very intresting read thanks for the link im very mechanicaly minded as i had my own garrage for years and used to break cars as well so should be well within my skill set just not sure on the cost even at £1400 it may be i a bit high even though im sure its worth it |
15th Feb 2011 10:37pm |
letsavit2 Member Since: 16 Oct 2010 Location: essex Posts: 854 |
1400 quid for landrover\bmw sat nav, my tom tom does a better job for 100quid.
16th Feb 2011 12:44am |
