Home > Maintenance & Mods (L322) > Front pads req for 2007 Tdv8 part no’s?
Tight777
I need pads for my Tdv8, they are Brembo callipers.
Are there more than one type?
I don’t mean makes or compound just shape fitment etc.
Also when fitting do the pistons just push back or do you need to bleed slightly.
Post #502360 22nd Jan 2019 5:39am
kbald
Only one type as far as i am aware. I replaced mine wih brembo from euro car parts with a 50% off code amd e part number was 10167024A. Cost about £26.50.
Re bleeding to get them in the pistons will push back if the top is off the brake fluid reservoir then its a pump of the brake to repressurise once all back together and top on the reservoir. Easy job as ling as the pins arent seized in place. Current 2007 TDV8 Vogue Buckingham Blue
Post #502457 22nd Jan 2019 7:53pm
nearlee
Wales
Same yr as mine, did them about 4 weeks ago, bought ebc green stuff from advanced factors, front wheels are still clean, very little brake dust. Remember:- amateurs built the ark
Proffesionals built the titanic
Post #502463 22nd Jan 2019 8:33pm
Tight777
Ta
Post #502517 23rd Jan 2019 12:22pm
Tight777
Off side first, 10 mins max.
Near side,,, pins stuck, well and truly stuck.
Post #502679 24th Jan 2019 6:03pm
kbald
Angle grind either side and then drift out the rest of the pin. New pins then would be the easiest way Current 2007 TDV8 Vogue Buckingham Blue
Post #502680 24th Jan 2019 6:11pm
