Home > Maintenance & Mods (L322) > Anyone using Redstuff brake pads on 2010-12 / Brembos ?
Charles89
United Kingdom 2014 Range Rover SVAutobiography SDV8 Scotia Grey
A few pictures if they are of any help to anyone. So far, great performance very happy, and low dust
Post #502066 19th Jan 2019 7:00am
GGDR
Nice one Charles.
Quote:
I made sure to get the 2018>formula
I think you got the last batch, see my post earlier - I rang EBC and they said they have discontinued the Reds for Range Rovers... Unless it's the 322 they have stopped and the 405 still available? Must plug in 405 vehicle details and see if they come up... The caliper is the same right?, I wonder if weight would "allow" you to choose the Reds for a 405.
I went for Greenstuff pads in the end. Shopped around and got a best price from a place called Bearmach. Arrived next day so all good there, recommended.
Planning to do them today, can't wait for less dust!!! Not looking forward to doing in 5 degree weather though Big Cry . (Yeah I know I'm a lightweight)
I also really like that EBC's are made in the UK Thumbs Up Thumbs Up
. Cheers, Greg
Post #502070 19th Jan 2019 7:32am
GGDR
Your picture shows they are massive pads to hold in your hand too, huh?
Like a truck sized pad!! Thumbs Up Thumbs Up
I got my GreenStuffs, and I thought what is this, these are absolutely massive.
. Cheers, Greg
Post #502071 19th Jan 2019 7:36am
Charles89
Yes the pads are massive. Brembo callipers. I am looking to replace my rotors for floating ones next. Good luck with the change, post some pictures Thumbs Up
Post #502073 19th Jan 2019 7:58am
nino_nino
Charles89, I will be interested in floaters to, pass the info you find. Thanks, Thumbs Up 2012 TDV8 Black Edition
2000 Disco. TD5
1975 series III
Post #502078 19th Jan 2019 9:32am
GGDR
What's a floating rotor?
. Cheers, Greg
Post #502080 19th Jan 2019 9:46am
Charles89
This is my floating set up on my Audi S8 Plus. It's been tuned to 830BHP 1150Nm and a 0-60 of 2.4 seconds. The discs would continually warp under excessive load due to heat. A fully floating design allows the discs to expand under heat and contract when cool without twisting and warping the steel, as they sit on a chain link that slides up and down, it prevents this from happening. The drilled holes allow the gasses generated by the pad to pass through the holes and exit, rather than causing brake fade which is caused by a layer of gas build up between the pad and the disc that the pressure of a braking system cannot compress, so there is actually 0 contact between the pad and disc (extreme examples here, track use etc.) But you get the idea!
Post #502081 19th Jan 2019 9:53am
GGDR
Wow!
And now we need to see this S8 !!!
. Cheers, Greg
Post #502083 19th Jan 2019 10:00am
Charles89
I was not sure if it would be favoured on a RR forum! I will upload some pictures now and show you. I kept everything stock looking, as I wanted the wolf in sheep's clothing look, not an accident at Halfords. A rocket powered "Gentleman" arm chair if you will. Certainly seen off some expensive super cars in it's time. Much to the dismay of Mr 300k Lamborghini owner Thumbs Up
Post #502085 19th Jan 2019 10:09am
nino_nino
Found this in UK, maybe give them a call. price seems good.
https://www.bigbrakes4u.co.uk/brembo-brake..._2545.html 2012 TDV8 Black Edition
2000 Disco. TD5
1975 series III
Post #502089 19th Jan 2019 10:39am
Charles89
Post #502090 19th Jan 2019 10:41am
Charles89
That is per disc and does not include the bell. It's a rotor only replacement
Post #502091 19th Jan 2019 10:42am
nino_nino
do You know the price for bell and disk ? 2012 TDV8 Black Edition
2000 Disco. TD5
1975 series III
Post #502092 19th Jan 2019 11:02am
GGDR
Very nice S8 Charles.
Normally I'm a bit yawn at Audis, but your numbers grabbed my attention!
And I do love a sleeper saloon
Thumbs Up Cheers, Greg
Post #502096 19th Jan 2019 11:52am
dolph34
Ireland 2015 Range Rover Autobiography SDV8 Corris Grey
S8 performance figures are amazing for an executive saloon 👍👍 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #502168 19th Jan 2019 9:31pm
