![]() | Home > Technical (L405) > Jacking Point with Deployable Side Steps |
chopdogs Member Since: 17 Feb 2011 Location: Malmesbury, Wilts Posts: 40 ![]() ![]() |
Had a puncture so went on line to the LR website to understand where the jacking points are.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35476 ![]() ![]() |
i always thought that the steps had to be removed for jacking... |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7969 ![]() ![]() ![]() |
Not on the L405
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16306 ![]() ![]() ![]() |
Only on a 322 Stan... 405's use the step hinge bottom as a jacking point |
ahh..... |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3858 ![]() ![]() ![]() |
So I must be doing it wrong on my L322. I just deploy the steps which exposes the jacking points and then use my Sprinter Jack with no problem at all. Well that's not strictly true I have to be careful to place the jack in such a way that I can move the handle sufficiently to jack up. Geoff |
All different on the L405 unfortunately Geoff
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3756 ![]() ![]() |
The correct method - it’s all in the handbook (in mine it is may have been updated) 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
Thanks Alistair, I had't realised I'd inadvertently strayed onto Technical 405 must pay more attention in future. |
nubbin Member Since: 23 Jan 2012 Location: Sheffield Posts: 232 ![]() ![]() ![]() |
I had exactly this issue following a puncture (3 days after getting the car!) I called out LR services, so that they would be responsible for any damage) and he put the car into off road mode and jacked the car up on the (closed)side step hinge, which it seems is the approved method. |
