Home > Maintenance & Mods (L322) > 6 Pot Brembos -Pads and measuring discs (thickness) - tips?
Page 2 of 3 <123>
nino_nino
plenty of "meat" on the disks to have them cut ( 31mm min). you end up with brand new disks. If you have them cut made sure they cut inner surface that meets the hub to. Thumbs Up 2012 TDV8 Black Edition
2000 Disco. TD5
1975 series III
Post #501405 13th Jan 2019 12:51pm
GGDR
Gotcha thanks!
. Cheers, Greg
Post #501408 13th Jan 2019 1:41pm
GGDR
Have decided I'm looking for EBC Redstuff pads.
But surprisingly not too many sellers online inc. eBay - at least not matching by vehicle type - in my case 2011 4.4TDV8. i.e. 6-pot Brembos.
I also need wear sensors so looking for one place that sells both.
Was going to give Island 4X4 a ring tomorrow. Maybe EBC too, if I knew the EBC part number it might make shopping for a deal easier.
Anyone got any recommends?
. Cheers, Greg
Post #501409 13th Jan 2019 1:46pm
m@ttsFF
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
Www.Ebcbrakeshop.co.uk ? 4.2 SC - sold , now bought back
4.4 AdBlu Tractor - Stolen
Post #501412 13th Jan 2019 2:19pm
GGDR
Thanks, no Redstuff there..
Maybe they don't do them for the Brembos...
Opened another thread:
https://www.fullfatrr.com/forum/topic49870.html
. Cheers, Greg
Post #501414 13th Jan 2019 2:22pm
m@ttsFF
Well they are out of stock , but the part number is shown
dp32064c 4.2 SC - sold , now bought back
Post #501418 13th Jan 2019 2:31pm
GGDR
I'm getting a blank:
 Cheers, Greg
Post #501419 13th Jan 2019 2:33pm
m@ttsFF
Post #501421 13th Jan 2019 2:37pm
GGDR
SO weird!
Thanks Matt!
. Cheers, Greg
Post #501423 13th Jan 2019 2:43pm
GGDR
Guys do I need to replace the wear sensor?
(the sensor has just activated)
Or is it integral in the pad and the cable will plug straight into the pad?
. Cheers, Greg
Post #501516 14th Jan 2019 3:32pm
great how to from the wiki greg..
https://www.fullfatrr.com/forum/post197471.html#197471
Post #501517 14th Jan 2019 3:40pm
GGDR
Hi Stan, yes read that yesterday, thank you.
I'm just not clear if the wear sensor is a separate, destructive part?
Mark says:
Quote:
as always remember to detach the brake sensor so you dont have to buy another one....
 Cheers, Greg
Post #501518 14th Jan 2019 3:47pm
nino_nino
Greg, wear sensor is separate part and if it did come on must be replaced, easy to do and not to expensive.
2000 Disco. TD5
1975 series III
Post #501519 14th Jan 2019 3:51pm
GGDR
Amazing thanks Nino!
. Cheers, Greg
Post #501520 14th Jan 2019 3:52pm
Baltic Blue
Greg,
Good luck getting the pins out, mine had only been in 18 months and the pads were only half worn, but the bottom pins on both sides were devils.
I know some people say you shouldn’t use copper slip grease on them, but when I eventually got them out and cleaned them I decided to use some and then clean off all the excess once they were refitted.
Mike
 G reg 2.5VM Vogue Portofino red 1991- 1999
Post #501525 14th Jan 2019 4:13pm
Page 2 of 3 <123>
