Home > Maintenance & Mods (L322) > Additional Battery Capacity |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2487 |
I have switched-in my 100ah rear battery on several occasions to provide starting current when the main battery is too flat. The 100A cable can withstand many times its rated current for the short period required to start the engine. I fitted a 250A resettable CB at the 2nd battery in case a short circuit occurs along the 100A cable yet withstands the short duration starting current. The CB doubles as a battery switch. The 2nd battery is charged via a VSR. |
23rd Nov 2018 11:20pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3977 |
^ aggraa. You wouldn't happen to have a link to the solar panel you used by any chance? |
24th Nov 2018 10:40am |
Rapiscan Member Since: 28 Apr 2018 Location: North Lincolnshire Posts: 182 |
Having an isolator on the starter battery enabling everything else to run on the aux battery is all well and good but what if one forgets the main battery has been isolated and attempts to start the car,wouldn't the wiring from the aux battery suffer as it attempts to feed the starter motor or would the 100amp fuse on it blow? 2008 L322 Vogue 3.6 TDV8 in Java Black with parchment and Navy interior. 125000mls.
12th Jan 2019 11:54am |
I've had my second battery on the car for over 3 years now and switched off the front battery on numerous occasions and to date haven't forgotten to switch the front battery back on before starting the car. If you have a worry about this it would be a simple matter to clip or Velcro a small notice on the steering wheel or over the keyhole, assuming you have one, indicating the front battery is switched off.
12th Jan 2019 3:43pm |
Thanks for your responses.I will use an isolator on the front battery.With regards to fitting a VSR,do I cut into the cars original positive red cable carrying the voltage to the rear fuse board Or to the new positive cable going from the rear battery connected to the same point as the first cable,or either? Many thanks. 2008 L322 Vogue 3.6 TDV8 in Java Black with parchment and Navy interior. 125000mls.
12th Jan 2019 8:03pm |
...OR having read that a VSR should be fitted as close as possible to the cranking battery,fit it onto the positive cable right next to the battery? Bloody confoosing this electickery! 2008 L322 Vogue 3.6 TDV8 in Java Black with parchment and Navy interior. 125000mls.
12th Jan 2019 8:27pm |
D17 JWB Member Since: 29 Aug 2018 Location: Olney Posts: 32 |
Like this one? MagiDeal Auto RV Marine Motor Circuit Breaker 20A-50A Manual Reset with Waterproof Cover - 50AMP https://www.amazon.co.uk/dp/B07FCPM3PH/ref...BCbYWPCBT2 2006 L322 3.6 TDV8 Dogs in the back, Kids in the middle, Horses in a box at the rear. I know which makes more mess. |
22nd Feb 2019 8:05am |
