![]() | Home > Maintenance & Mods (L322) > Front disc brakes getting hot |
m@ttsFF Member Since: 12 Dec 2017 Location: Surrey Posts: 333 ![]() ![]() ![]() |
Brake hoses can collapse internally preventing fluid return so symptoms are similar to a sticking caliper 4.2 SC - sold , now bought back
JT Member Since: 28 Nov 2016 Location: Hailsham. East Sussex Posts: 39 ![]() ![]() ![]() |
thanks for suggestion. Had thought of this but assumed because they were replaced under recall in June 2015 they wouldn't have caused a problem but will replace just in case. |
TomCobbly Member Since: 29 Jun 2016 Location: Guildford Posts: 122 ![]() ![]() ![]() |
You may have moisture in your brake fluid at the caliper which can cause this. You could just try bleeding some fluid out and seeing if it is clean. 2011 4.4 TDV8 Vogue SE
I did bleed the system when changing the caliper but maybe not enough. It will get a full change when I replace the hose. cheers JT |
