![]() | Home > Wheels & Tyres > Wheel/tyre swap and now rubbing - L322 |
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2681 ![]() ![]() ![]() |
If it’s rubbing from the rear, the arch liners can be adjusted with a self tapper, used to be a bodge when larger off-road tyres were fitted. The rubbing on the front migh5 be from the bottom plates end of the strut, almost like a plastic split pin that can be cut off. If you search for I think cooper Zeons, the threads should come up |
DBB Member Since: 18 Mar 2016 Location: United States Posts: 42 ![]() ![]() |
It would be helpful to share what the wheel specs are (width and offset) and also which areas it is rubbing. |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7905 ![]() ![]() ![]() |
You’ve gone from the sidewalls being 35% of 265 mm to being 40% of 295 mm, so I’m not that surprised. The whole thing is bigger in the wheelarches. 2011 Range Rover Vogue SE 4.4 TDV8
Ramsden78 Member Since: 23 Sep 2018 Location: London Posts: 42 ![]() ![]() |
Not sure about offsets etc. I know next to nothing about tyres/wheels I am afraid. Assuming all alloys are the same offset I will detail them below.
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3783 ![]() ![]() |
295/40/22 on an L322 is bonkers, they are 33mm oversize in diameter than std and are 40mm wider than std on an L322
This shows the std 255/50/20 size for an L322, compared to what you have - there is no wonder it is rubbing. 275/40/22 is std size fit on an L405, yes you can get away with 285/40/22 on an L405, but 295’s are even too big for a L405, - 285’s only just clear and usually catch on the inner wing liner with some alloys - on a 322 that size will not work without issues in that aspect ratio and on 22’s - that is unless you want to drive around in extended off-road mode all the time. If you want to keep the 22’s if anything I’d go for 285/35/22 as these are the nearest to OEM in diameter:-
This will also be dependant on the offset of which alloys you are running - if they are genuine Turbines then they should be ok as they have more offset than std 322 oem alloys. I have run virtually every tyre option on both 322’s and 405’s on standard suspensions in 18”, 19”, 20” and 22” in std road tyres, winter tyres, AT and muds in most widths so have a jolly good idea of what works and what doesn’t ![]() |
Thank Vogue, you seem to know what you are talking about and the type of help I was hoping for..
The 265/35 you have are too small in diameter for a 322, my guess those wheels and tyres were originally for an older series 1 Range Rover Sport as they ran smaller dia tyres.
Ramsden78,
Ramsden is running a 322 - is that modable as per the 405? 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
horse86 Member Since: 09 Dec 2014 Location: PA Posts: 863 ![]() ![]() ![]() |
285/40/22 is the widest 22 you can go without rubbing. Have run these personally. 2014 FF Autobiography 5.0 SC
I’ve got two sets of tyres and wheels on an L405, 275 and 285’s - the 285’s catch on full lock on std RR rims. 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
Hi guys,
should have went 40's for extra sidewall :shrug: 2014 FF Autobiography 5.0 SC
