![]() | Home > Off Topic > Anyone project managed an extension themselves? |
socialrover Member Since: 03 Dec 2010 Location: Yorkshire Posts: 140 ![]() ![]() |
"Whoever you employ you will also need to check their insurance. Check their Public liability, employers liability and contract works insurance and that it has sufficient cover levels for the project and any damage that could potentially be caused."
mrblonde Member Since: 24 Jan 2012 Location: Cambs Posts: 732 ![]() ![]() ![]() |
Cheers all, will get round to reading all your replies and replying once I'm back to work, been on a b@st@rd spring clean today with the missus since 10am!! |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7975 ![]() ![]() ![]() |
If you're quick they should be amenable - until May 19 Permitted Development would allow 8m on a detached, 6m on a semi unless your neighbours have a reasonable objection. Assuming you have enough of the original plot left as garden. |
IMHO always better to go with full planning as it's beyond any dispute or interpretation, particularly when you come to sell - it just costs a few hundred pounds more & takes a few weeks longer.
Hi (again) Alastair
Firstly a planning application is all about how it will look - no structural details needed - that comes later
ajac8 Member Since: 04 Oct 2011 Location: Shakespeares County Posts: 1661 ![]() ![]() ![]() |
Check with building control before paying for calcs. They don't always need them and the better services actually agree steel and padstone sizes based on experience and common sense for simple schemes. Plans for a single storey box should be max £500 to include planning and regs. Calcs would be an extra £150-180 all plus vat. Dont bother with a qualified Architect if you have a good idea what you want to create- they cost a fortune and often bring little more too the party than any well respected planning or architectural technician of which there will be many to chose from locally.
Last comment re RSJ, we fitted a catnic last year when we replaced french doors with wider bifolds (non supporting wall) but realise is similar in cals and installing |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8687 ![]() ![]() ![]() |
A standard steel will normally be a cheaper option than a catnic if you can use one👍🏻 Steel stockholders are your friends for this. If you have a cavity wall and are going inside to inside then they will drill and Sleve/spacer 2 steels which you then bolt together. There is nothing that can't be fixed with a hammer😜😜
Thats what I had - original plan was a goal post, but with a little thinking was able to leave enough wall either side to allow just a beam across the top - then had 2 x C section beams back to back with spacers between them where the bolts are. |
