![]() | Home > Maintenance & Mods (L405) > Replacement L405 keyfob - how does it work? |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16315 ![]() ![]() ![]() |
You can either change over the electronics inside (easy enough) or you can code a new key using your IID unless your car has had a security update at JLR (usually at service point) then you won't be able to code a new one yourself Ryan as JLR lock down the key ECU to prevent theft... |
Cheers Craig |
Matford LR selling them for £12.49 incl delivery on eBay. Spotted just as one of ours has started coming apart |
