![]() | Home > Technical (L322) > 3.6 tdv8 knock sensor wiring.... |
Grofus Member Since: 24 Mar 2017 Location: Co Clare Posts: 577 ![]() ![]() ![]() |
arnt they for the Egrs 2007 Vogue TDV8 in Zermatt Silver with Charcoal |
ptaroni Member Since: 20 Dec 2015 Location: leicestershire Posts: 89 ![]() ![]() ![]() |
Hi, no they are definately for the knock sensors, there are two on either bank. I just find it strange how they both can be plugged into each other easily and have the same colour wiring... a couple pictures of the looms similar to my picture should allow me to get them the correct way! Looked through google images etc but nothing clear enough.. 2004 td6 l322 - gone
Been looking on egr removal procedures from other members guides and still cannot see these connector plugs. I can see the metal brackets that these clip onto but no plugs.. im now a bit confused.. also i have access to e3technical data and delphi direct evolution and neither of these mention knock sensors on their wiring diagrams...
Assuming you right and they are the knock sensors, is there an issue you need to resolve.
Not neccesarily an issue... wasnt feeling right and a bit diesel knocky when cold, more than it should but by no means alot. Had a similar car in at work so took photos of the live data to compare and nothing different apart from the cylinder balances... injector number 8 was around 1050 , another was 900 and the others around 700.. then a few days after that the car went into limp mode and then found the manifold was cracked, used some sikaflex again to seal and then they pretty much evened them selves out between 850-950. I know how the knock sensors work, just assumed as there were two either bank i would have thought it would matter which was which unless its backs the timing off across the board of that makes sense!
lol. I think you've answered your own question |
