Home > Maintenance & Mods (L322) > GM Box question
Ferret01
Ireland 2004 Range Rover HSE Td6 Santorini Black
GM Box question
Merry Christmas from a new member. I am currently restoring an 04 td6 and am having some strange behavior from the transmission.
It works perfect in drive, goes through all the gears 100% with no issue both hot and cold but when I try reversing that’s a compleat other issue in its self.
The car will go into reverse but not move unless you rev up to 1500/2000 as soon as you drop the revs that car stops almost as if you stood on the brakes.
Also if you put it into neutral the car will move forward.
While I know the boxes are made of chees but have not found some one with similar faults.
Thanks
Post #499742 27th Dec 2018 12:57am
Have a look at the connecting rod on the right hand side of the gearbox (from the lever) - may need greasing/releasing
Check gearbox fluid level
Otherwise, maybe RRPhil can advise on it being something more drastic! .
Post #499756 27th Dec 2018 9:20am
Ferret01
Thanks for the reply! Tried adjusting the cable but no luck as it did not make a difference (would not select anything) Fluid level seems to be correct.
Honestly a bit lost at the moment.
Post #499783 27th Dec 2018 2:12pm
