Home > Technical (L405) > L405 "design faults"?
Page 2 of 3 <123>
mjdronfield
Front fogs deliver a wide short beam pattern, which, being low, helps you to see the kerbs/edge of road in foggy conditions. They are not particularly designed to help others see you. The rears do that, and I always turn my rears off when a car comes behind me in fog, as obviously they have seen me.
But low down lights appear to be used for all sorts of things nowadays. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #499694 26th Dec 2018 2:00pm
Emperor Mong
United Kingdom 2019 Range Rover Autobiography 2.0 PHEV Loire Blue
Map reading lights in the rear are easy to turn on accidentally and then keep coming on every time the ignition is turned on (but there is no way to turn them off from the driver's seat
Post #499734 26th Dec 2018 10:13pm
Red Merle
United Kingdom 2017 Range Rover Autobiography SDV8 Aintree Green
The sheer width of the car, combined with doors that are 11” thick, mean that it won’t fit in most multi-storey car parking spaces (and still be able to get in and out of the car) and it’s even too wide to legally pass through 6’6” width restrictions Shocked
Post #499743 27th Dec 2018 2:06am
CJB1000
United Kingdom 2015 Range Rover Vogue SE TDV6 Santorini Black
Just a few to be going on with.....
Rear fabric covered Parcel shelf gets drips on it (from the upper tailgate) when it is wet or in rain, causing watermarks.
The rear tailgate spoiler rubs against the D pillar high-gloss trim and has rubbed away the surface due to ill fitting.
The upper passenger dash cubby size is useless.
The fitted driver’s front carpet mat does not cover behind foot pedal area and consequently dirt builds up here very quickly.
C
Post #499894 28th Dec 2018 5:09pm
I couldn't stand the mats not fitting either so i bought these... Thumbs Up
Post #499895 28th Dec 2018 5:14pm
pld118
Sounds like knocking the car here but not at all, it's brilliant... there are wee things you always notice though:
The cup holders in the centre console have a bad habit of lifting out and sticking to the bottoms of bottles of water🙄
On long journeys, when resting the right elbow on the top of the driver's door (RHD) it becomes a bit uncomfortable as thought the finish could be more cushioned/plush.
Post #499904 28th Dec 2018 6:16pm
Philip
2019 Range Rover Autobiography SDV8 Aintree Green
The driver’s side genuine rubber mat is rubbish too.
Post #499920 28th Dec 2018 8:53pm
The Renault Captur and the later Ford Fiesta has a little round gripper that fits in the small centre hole and stops the cup holders pulling out Thumbs Up
These also work on a 322 & a D4
https://www.ebay.co.uk/itm/GENUINE-FORD-FI...:rk:4:pf:0
https://www.google.co.uk/search?q=renault+...ybtGAitCM:
Post #499922 28th Dec 2018 9:01pm
Andy B
The fridge is a PIA to get to and I miss the sunglasses holder from the L322, but other than that I think generally they have done a decent job Thumbs Up SDV8 AB MY 2019
SDV8 VSE MY 2015 - Gone
5.0 S/C AB MY 2010 - Gone
4.2 S/C VSE MY 2006 - Gone
Post #499934 28th Dec 2018 10:04pm
Red Merle
That’s a good point about the fridge and why doesn’t the top fold back to 180 degrees to get completely out of the way of the driver’s elbow and then fold down flat to form a handy tray for rear seat passengers, just as used to in the D4?
Post #499939 28th Dec 2018 11:08pm
AndyS
It could also helpfully slide forward to make a more comfortable armrest rather than the skinny thing which I find uncomfortable.
I think our old Alfa use to have a sliding armrest so it won't be expensive to add.
Post #499954 29th Dec 2018 9:24am
Red Merle
Where did you get those?
Post #499958 29th Dec 2018 9:39am
Its a swear word i know but they are manufactured by Britpart Shocked Shocked Shocked
Part number DA4820
Post #500033 29th Dec 2018 11:39pm
Red Merle
Thank you Thumbs Up
Post #500037 29th Dec 2018 11:52pm
Post #500038 30th Dec 2018 12:01am
Page 2 of 3 <123>
