Home > Technical (L322) > Another noob question of parking heater and pre heater
Lester Burnham
Hi all, thanks to some cold days I've established both these function now, however a couple of things still bug me;
The parking/residual heater - after pressing MAX AC mine works nice and hot but only for about 2 minutes at most before switching off. Is this due to a weak battery? How long should it puff for?
The FBH/pre heater - how long before getting in do you start it to produce some meaningful heat? On a morning before work, and by the time my slurred brain actually remebers the function exists, its only on for about 5 mins before I step out the door. I'm greeted with stinking diesel fumes so know its working and can hear it puffing away inside, but its nowhere near warm in fact I'd call it cold...
Post #499482 23rd Dec 2018 10:05am
Nick591
In my experience on a frosty morning with ice on the windscreen the FBH needs at least 15 min to make a useful difference and melt the ice. 20 -25 min better yet. I think it shuts off automatically after 30 min. Previously a 2008MY Tonga Green Vogue SE 3.6 TDV8
Post #499484 23rd Dec 2018 10:10am
mjdronfield
The heater will run for a max of 30 minutes, so I aim to get to the car at about 25 mins.
The max AC thing doesn’t use the fbh, just the heat in the water. No idea if it’s any good or how long it runs as I’ve never used it.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #499491 23rd Dec 2018 11:12am
Lester Burnham
Cheers I'll have to remember to switch the FBH on before making my sandwiches!
The residual heater, well I was expecting more from this to be honest, maybe the short duration is battery condition related?
Post #499502 23rd Dec 2018 12:34pm
mjdronfield
You should be able to manually turn the FBH on before you leave someone in the car and use that for warmth if you need to.
Though obviously battery dependant. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #499503 23rd Dec 2018 12:39pm
JST
England 2012 Range Rover Westminster 4.4 V8 Stornoway Grey
the residual heat only blows air through the heater matrix after 2mins or so its cold anyway.
FBH - 15-20mins i sue mine for in the winter. Cheers
James
Post #499536 23rd Dec 2018 7:03pm
Lester Burnham
Cheers both, do you use the menu (2010 0n) or just plip the little remote again?
Post #499600 24th Dec 2018 5:53pm
Devilish
The FBH runs a self test during start up, anything wrong with the FBH, then it will purge the combustion chamber for 2 mins, then shut off. If it fails to start 3 times in a row, the PCB locks out the starting sequence, pulling the fuse for a spell can reset the lockout, but it does not cure what caused the lockout. If the FBH starts up ok, it can take about 2 minutes for it to ramp up to full speed. As previously said, hard for it to run hot for 2 mins when it takes longer than that to start up.
Post #500975 8th Jan 2019 10:32pm
Lester Burnham
Thanks for that info, sorry not to acknowledge, just seen this been too busy for the internet for a few weeks.
Sounds like a fuse oull wouldnt hurt - still to warm at the moment, shouldnt complain though!
Post #501532 14th Jan 2019 4:30pm
